Thread: Low Ca and high TA
    JenMichelle's Avatar
    Apr 2014
    St. Louis
    65
    Low Ca and high TA
    I'm a new pool owner and just really want a little reassurance on my test results. I use th TF 100 test kit. I am a little concerned with the high TA and low Ca.
    Cl 5.5
    Cc 0
    Tc 5.5
    TA 150
    Ph 7.8
    Ca 50 or 75
    Cya 55
    It seems the ph slowly keeps rising in my pool. I have had no problems this year except for metal staining and did refills for high cya due to old house owners using pucks. Should I add acid to lower the TA? Thanks guys!
    24' x 52" AG / Hayward Sand Filter
    Hayward Power-Flo 2 Speed Pump
    TF100 test kit / Pool Rover Hybrid Robot
    St. Louis, MO *GO CARDINALS*
    Re: Low Ca and high TA
    You should only adjust TA if you are actually having a problem. If your PH is going up annoyingly quickly, then lower TA.
    There is never any need to raise CH levels in a vinyl liner pool.
    Apr 2014
    St. Louis
    65
    My ph is going up from 7.3 ish to 7.8 within 7 days or so. I guess I will wait and see if it keeps happening! If so I will adjust. Thanks for the quick reply ��
