Thread: Pentair Minimax NT E04
    Jun 2014
    McKinney Tx
    1
    This morning I got an E04 code. The fan won't engage at all.
    I removed the panels, the fan motor is very very hot but does not operate.
    It takes a couple of minutes before the E04 code re-appears after each time that I reset the power switch.
    How do I know that this is only a bad fan motor and not something else?
    BK
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Pentair Minimax NT E04
    Pull the motor and see if the squirrel cage is still intact or all rusted. If it is in good shape and spins freely, then I would suspect the run/start capacitor.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
