Results 1 to 7 of 7
Thread: CYA confusion after AA treatment
    Ladies and gentlemen:
    I am two weeks past a successful AA treatment to lift staining from a vinyl liner. I am now getting test results that are basically not measuring any CYA, when I was high all last year. In the middle of last season, CYA was 100 and I had to partial drain to get it down to around 75. I wasn't really testing CYA this spring, assuming it wasn't moving. Now after AA treatment, I am having difficulty keeping any FC levels at all, and am not registering CYA with my test kit. Can the AA treatment directly affect CYA, or can the CYA deplete on its own, or should I look at replacing my reagent?
    Stumped again...
    Thanks.
    FC 0-4.0
    pH 7.2
    TA 110
    CH 130
    CYA 0-?
    South Carolina, in ground 30000 gal vinyl liner, sand filter
    Re: CYA confusion after AA treatment
    CYA can vanish sometimes, especially over the winter when FC goes to zero for a long period.
    As long as your CYA reagent is less than two years old, I would go ahead and add more CYA. If your test reagent is older, there is some chance that the reagent has gone bad, so I would try to double check the CYA reading somehow before adding more.
    Thanks-I suppose I will have the local pool store recheck the level for me. Any suggestions for bringing CYA up?... I haven't had to do that before because it has always been high. Thanks again.
    You raise CYA with cyanuric acid, sold under several names: stabilizer and conditioner are the two most common. Those names are also sometimes used for other products so check the ingredients. You are looking for 95+% cyanuric acid.
    30,403
    Doing an AA treatment successfully takes some precision and attention to detail. I am quite surprised you would go to a pool store for test results of any kind....particularly CYA.
    duraleigh, I believe they are trying to double check a reading made with several year old CYA test reagent, as I suggested above.
    30,403
    Sorry....I overlooked that part of the thread.
