Thread: The reason for keeping PH at 7.5...
    May 2014
    Mesa, Arizona
    180
    ...is because human's PH is 7.42. And there you go.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: The reason for keeping PH at 7.5...
    The pH of human tears according to this paper for 20 subjects showed 7.50 (SD +/- 0.23) while this paper for six subjects showed 7.500.16 (SD). However, this paper for 44 subjects showed a range 6.5 to 7.6 with a mean value of 7.0.
    According to this paper the pH of normal skin is in the range 5.4-5.9.
    This paper talks about various factors affecting eye irritation in swimming pools. The primary factor for irritation appeared to be osmotic pressure since adding salt to the water at around 0.5% (around 5000 ppm) in the field study or 0.7% (around 7000 ppm) in the lab study virtually eliminated the irritation which isn't much of a surprise since the salinity of human tears is around 9000 ppm. The pH varying from 7 to 9 did not show a significant difference in irritation.
    May 2014
    Mesa, Arizona
    180
    I think it was the PH of human's blood that I was referring to, I read it in an article and thought to post it here. Should've been more clear, sorry.
