Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: How much chlorine do you put in daily?
    May 2014
    Houston, TX
    155
    For non-SWG folks, how much liquid chlorine do you usually put in each day?
    I'm on week 2 of BBB, and it seems my 12k gallon pool with CYA ~ 45 needs a quart a day, maybe a little splash more. I live in sunny Houston, it's 90 degrees+ already, and my pool has no shade at all. Quart a day adds about 2-2.5 ppm, so that sounds about right?
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: How much chlorine do you put in daily?
    With a CYA of 100 I keep my FC between 10 - 12. Depending on the day between 1 and 2 quarts does the trick.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Never mind . . .
    Solar Blanket, Well Water, Borax Added. 68
    Yes, 2 ppm, or just a little more, is very common.
    Jun 2013
    East TN
    309
    CYA of 40 here and I put in 2 to 3ppm of bleach/chlorine. 6-9 cups for my size pool.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'm at about 3.5 ppm per day at 35ish CYA. Still need to retest level after bumping it up. My pool had been used nearly every day by 3 to 5 kids and myself in the last 3 weeks.
    Isolated Spa - 345 Gallons
    Aug 2013
    Tucson
    56
    Congratulations!
    My pool is brand new also - first swim was May 13th!
    My CYA is about 30 ppm. I am putting in about a quart myself (11,500gal). I'm in Tucson where it has been exceptionally hot and sunny (over 105 without a cloud in the sky). When the kids are playing a lot, I will throw in 6 cups. I've been using a solar cover to raise the temperature of the pool to 88-90degF.
    Old: 50 gallon bathtub, white fiberglass. Single drain. Faucet and "rain" feature. Elbow grease cleaning system.
    New: 28x15', 11.5K Gunite, 480 sqft cartridge filter, Pebble Fina Grigio, Glow-in-the-dark accent tiles. 30' Negative Edge. Aquabot Turbo T-Jet Robot. 0 sq ft pool deck. TF-100. Tucson Pool Build
    Isaac-1's Avatar
    SW Louisiana
    6,711
    This sounds about right, my only suggestion is that you may want to boost your CYA to 50 ppm since you are in prime sun belt part of texas and get full sunlight on your pool
    jccams's Avatar
    Dexter, MI
    95
    I lose about 2.5-3ppm and add 60-72 oz/day depending on sun and temp.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    May 2012
    Montville NJ
    545
    I keep my CL around 5.5 ppm and my pool uses just over 1 ppm per day with a CYA of around +/- 40
    I put in a quart container of 8.25% bleach each morning.
    Depending on usage /rain / etc somtimes I have to add an extra half quart or so to keep the levels up.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    May 2014
    Upstate NY, US
    64
    I put in between 2-4 ppm, depending on the day.
    My pool: 13,500 gallons round pool, 24' w 52" above ground, hard sided pool. Jacuzzi 190L Sand Filter, 1 Horse Waterway pump, Robotic Vacuum
    Jun 2013
    Newcastle, Oklahoma
    508
    our pool was consuming 3 ppm per day at 35 ppm CYA, which was a whooping 90 oz of 8.25 % per day. I posted about increasing CYA to lower FC usage. Now at 50 ppm CYA, its consuming only 2 ppm (60 oz). Someone asked me on here when I posted, "Whats 1 ppm?"
    well, in this pool its 30 oz of bleach!
    by getting it down to 2 ppm per day, its taking 1/2 a bottle of bleach per day instead of 3/4 a bottle, which puts me at about 15 bottles per month vs 22 bottles.
    so that 1 ppm is quite a bit, actually.
    im sure on some days im still gonna spike to 3 when we are swimming a lot. But I want to keep it at about 2 ppm per day when we are not swimming or light swimming.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Mar 2010
    Spring, TX
    1,082
    I am in Spring, TX and my pool has no shade. I lose on a typical day 1.5. Sometimes depending on weather or swimmers 2-3. When I start losing more than 2 PPM per day that is a sign that my pH level may be high as well.
    CYA is at 50 as well.
    I typically add 24-40 ounces of 8.25% bleach.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    1.5 ppm daily. I usually only add every three days or after heavy swim load.
    26k IG Vinyl, 2 HP single speed,24" Tagelus Sand, 1.5" pipe, 1 Main, 1 Skimmer, 2 jets, pool built 1983, new vinyl 2014, 36'x18', Deep End 8', The PoolCleaner 4X Suction.
    Pool Math #__# Pool School #__# Best Android App "Pool Pal" Track Your Levels!
    Exactly 1 McDonalds foam cup of 8.25 per day! Give or take. CYA at 50. 20,000 gal
    Feb 2014
    Central Minnesota
    5,080
    Looks like either rain lately or extra kid usage is increasing my usage. May have to do some attempts to lower daily loss.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by JVTrain View Post
    Sent from my SCH-I545 using Tapatalk
    i guarantee you wont regret bumping it up to 50 ppm. that will surely lower your loss to sun and the initial dose to get 'er going isnt much above what you need for 35 ppm. it cut my bleach usage by 1/3 rd.
    Feb 2014
    Phoenix, AZ
    51
    60 CYA in Phoenix, AZ; or as we prefer to call it 'The Sun's Anvil'. no shade, daytime hits 110, pool up to 90 already - 3ppm / day for me. which translates basically to a half gallon a day. since it's either a full bottle going to somewhere randomly close to half, or an open bottle going empty; measuring is not even remotely important to me. I keep a separate weekend bottle handy if I need a little boost on weekends when I do a more comprehensive set of tests.
    20k IG PebbleTec w/ STA-RITE PE5E-182L 1HP and Zodiac Polaris PB4 for Polaris 380 vacuum / Hayward ProGrid DE4820 Filter / TF-100 but I havent broken down and gotten a speed stir yet
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    ~2 ppm per day, give or take with CYA at 40.
    Works out to about 2 121 oz jugs of 8.25% every three days. Sometimes it's 3 jugs every 4 days depending on how often the dog goes for a swim
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
  20. Back To Top    #20
    Feb 2012
    Cypress, TX
    131
    About the same for me. CYA around 50. 2+ppm per day. One jug of 8.25 raises my ppm by 3. So I add a jug for two days then skip a day unless testing reveals it needs it more frequently.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
