Results 1 to 10 of 10
Thread: Piles of leaves - was that my problem
    Jul 2011
    Huntsville, AL
    96
    So I've been fighting to clear my pool for 3 weeks. I made progress to the point where I was starting to see the bottom of the shallow end. I remembered that I had not really scooped out leaves in the deep end all that much so I decided to do that this morning.
    OMG. I probably have pulled 15-20 pool nets full of leaves out. All scoops were full with algae. Could this be why my pool was not clearing? I'm slamming it now and it is losing 3ppm of chlorine. I'm shocking at 20. Hourly it is dropping to 17. When should I expect an improvement?
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Piles of leaves - was that my problem
    I expect it was at least a big part of the problem. If you can stay at it with hourly dosing and brush it a couple of times today you should see improvement in chlorine consumption later today and visible improvement tomorrow.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    I'm willing to bet there's STILL another 15-20 scoops you could physically remove if you can't see bottom. Clearing all major debris you can possibly get out is always Step 1. What are your full test results including cya?
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by woodyp View Post
    I'm going to test in an hour. My CYA was at 50 yesterday. PH was at 7.4 this morning. I'll redo everything and post results at around 1145.
    Jul 2011
    Huntsville, AL
    96
    FC 20
    CYA 50
    PH 7.4
    TA 90
    Pressure was 18psi an hour ago it is now up to 20psi.
    Jul 2011
    Huntsville, AL
    96
    Every time I test and adjust I'm pulling out leaves. It seems like I'm pulling out less. I'm still getting about 5 good scoops each time. I think they settle between when I'm testing. I feel like an idiot. I've wasted 3 weeks because of mounds of leaves in the deep end of my pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    That makes two this season! May I use this thread as an example to show what happens when you skip steps in the SLAM article?
    Apr 2010
    East Texas
    9,655
    We want to take you from feeling like an idiot to feeling good about taking control of your own pool with a solid knowledge base. I assure you that you're not the only one that has been in that boat before. Keep at it!
    Jul 2011
    Huntsville, AL
    96
    Lol yes. This forum has been a tremendous help since I switched to the BBB method. If my stupity helps others I'm all for it.
    sent from my Verizon Galaxy S3 on PPC.
    Richard320's Avatar
    Jan 2010
    19,073
    Actually, it would be better if you cruise the forums looking for "My pool is a swamp" threads and tell them how to clear it -- warning them of the pitfalls along the way.
