Thread: Wet circuit Breaker
    Jun 2014
    Randolph/New Jersey
    1
    Wet circuit Breaker
    While running off excess water yesterday I left the door open to the outside circuit breaker for the pool(not too smart). The water hose coiled around and splashed the circuit breaker tripping the switch and the pump shut off. It is still wet and the pump won't start a day later. Should I just wait for it to dry then try again or should I call a electrician.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Wet circuit Breaker
    Best bet is to call an electrician, and have him check everything. He may need to replace the breaker, and dry everything out.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Hit it with a leaf blower then give it a couple of hours drying time. If that doesn't work, run a hair dryer on it for a while.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Is the main breaker to this sub panel OK or does it need to be reset?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I like the leaf blower idea. I was thinking shop vac but whatever will blow some air on it. Get it dry first before you do anything.
    When you say it's still wet are you talking about inside the box or the breaker itself ?? Is the breaker a GFI ?? Will the breaker reset properly or does it pop off again ?? Have you checked the main panel ?? Is there a GFI in the circuit and if so where is it ??
    Solar Blanket, Well Water, Borax Added. 68
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What did you find out ??
