Thread: Vacuum heads with brushes
    Jun 2010
    74
    So a curious thing for me. Every vacuum head I've ever had for a dozen concrete pools has no brushes. They are specifically sold as concrete vacuum heads. Recently I took over a pool that has a nearly identical style head, except it has two alternating rows of brushes on the bottom. I was under the impression that heads with brushes were for vinyl pools, not painted concrete? This is a typical 8-wheel rectangular head, not any of the triangular or other funny styles I've seen for vinyl.
    Is there any advantage/disadvantage to brush/non-brush in relation to a concrete pool?
    * Responsible for the operation of 21 semi-private pools and spas at 11 locations, varying from 1,900L to 20,000L spas and from 13,000L to 200,000L pools.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Vacuum heads with brushes
    I don't know for sure why they don't have them, but my vac head with wheels and no brushes is worthless for the dust we are bombarded with.
    Essential Links:
