Just set up and filled my 20 x 52 ultra frame pool and noticed on a couple of the tee bar connections the pins that click in place are not fully slid in place. Is this okay or how do I fix it without having to drain all the water out?
Are they on joining posts, or one here one there, and is the pool completely full? You could try a ratchet strap; you may be able to pull the pieces together until the pins engage. Hook the two hooks together and ensure you protect the sides of the pool from the hooks. Tighten the strap until the pins go in. Make sure your strap is rated for several thousand pounds as the force of the water could cause a small strap to fail. If the alignment isn't right and the pins are off center you will most likely have to drain.
