Thread: Tee bar connection slid out!!
    Jun 2014
    Edinburg/Tx
    2
    Just set up and filled my 20 x 52 ultra frame pool and noticed on a couple of the tee bar connections the pins that click in place are not fully slid in place. Is this okay or how do I fix it without having to drain all the water out?
    May 2014
    Hunterdon County, NJ
    32
    Re: Tee bar connection slid out!!
    Are they on joining posts, or one here one there, and is the pool completely full? You could try a ratchet strap; you may be able to pull the pieces together until the pins engage. Hook the two hooks together and ensure you protect the sides of the pool from the hooks. Tighten the strap until the pins go in. Make sure your strap is rated for several thousand pounds as the force of the water could cause a small strap to fail. If the alignment isn't right and the pins are off center you will most likely have to drain.
    20500 gallon Grecian type 2 pool built in 1980's, Vinyl liner approx 2001
    2 Skimmers, 1 Dedicated Vac Line and 3 returns
    PureLine Prime PL2601 Pump - Hayward in line Chlorinator
    Triton TR-60 Sand filter
    Dolphin M3 robot, TF-100 with XL option & Speed Stir
    Jun 2014
    Edinburg/Tx
    2
    One here one there, and mostly full. I will try this, thanks!
