Hello TFP folks,
I have spotty green algae on the plaster and tiles. Water is perfectly clear. Been using chlorine tabs in two pool floats for a couple months then blindly shocked heavy with HTH calcium hypochlorite -- four one-pound bags three weeks ago that helped a little. Then HTH Super Algae Guard to no effect. Dumped three more bags of HTH calcium hypochlorite last weekend. Have also brushed and vacuumed twice a week and cleaned the filter grids then recharged with DE.
Now I'm getting serious. HTH test strips tell me:
pH 7.5
Hardness 600ppm
Alkalinity 120ppm
TOTAL Chlorine (off the chart, estimated to be ~40ppm by testing a 10X dilution)
FREE Chlorine Unknown
Cyanuric Acid 80ppm
I can come back with better chlorine numbers on Monday: I work at a lab so can do free testing. ATM these are test strips results.
Tonight I drained three inches of water and added four inches back, then dumped two gallons of 8% hypochlorite bleach into pool after brushing.
We're having drought here in N Texas so I don't want to drain/refill any more water for now. So what to do about the algae?
Next problem: Apparently there's a leak on the vacuum side. I get bubbles coming out the jets and even after bleeding the DE tank they won't stop. When the pump stops the basket has to be re-primed every time to start up again, or run pump dry for 30 seconds which I assume is very hard on the pump.
Thanks for any advice and replies. This pool came with the house so time to learn...
pH 7.5
Hardness 600ppm
Alkalinity 120ppm
Cyanuric Acid 80ppm
