Thread: AquaTrol - No Lights on Control Panel - AGP
    Jul 2011
    West Monroe, La
    67
    Hey
    We came home from vacation and my chlorine level had dropped significantly. When I opened the control panel I noticed none of the lights were on. When I turned the pump off and back on the no flow light flashes for about 15s which is normal than the generate light stays solid green for about 10s and shuts off - any ideas, do I need a new control box?
    Thanks
    Clint
    27'x54" Matrix Resin - 200lb Pentair sand filter - 1.5hp Pentair optiflow 2 speed pump - Aquatrol SWG - Gorilla Pad
    May 2013
    Ottawa, On, Canada
    32
    Re: AquaTrol - No Lights on Control Panel - AGP
    I know i'm about a month late, but this just happened to me and I stumbled on your post. Sounds like you have this problem
    http://www.troublefreepool.com/threa...-lights-not-on
    or
    http://idoneitmyself.com/2009/08/23/...-by-lightning/
    Long story short there is probably a damaged part on the circuit board in your generator. If you're at all handy with a soldering iron (or know somone who is) the part costs about $10 with shipping, where as a new circuit board costs ~$250.
    27' AG Round (~17000 Gallons or 64000 L)
    Hayward 1.5 HP Power Flo Matrix Pump (2 speed usually run 6hrs high 18hrs low)
    Hayward CC150CAN XStream Cartridge Filter (150 ft^2 120 GPM)
    Hayward AquaTrol SWG
    Installed April 2012
    Jul 2011
    West Monroe, La
    67
    It was the inrush limiter - I changed it out a couple weeks ago - thanks
    May 2013
    Ottawa, On, Canada
    32
    Quote Originally Posted by swanny297 View Post
    Quick question actually, did you use the 570-1062-ND from digikey? Mine has a different model than most I see on the internet but physically it looks the same.
    Jul 2011
    West Monroe, La
    67
    Yeah mine did as well the only difference is the width of the wire terminals but you can spread them easily to line up with the board
