Thread: What pump to replace Jandy MHPM 1.5 with
    Jun 2014
    Sayville, NY
    1
    I have a 38K gallon pool with a hot tub flowing into it. I have 2 Jandy MHPM 1.5 pumps that are 9 years old, one for the pool and filter, the other circulates the hot tub. I new to replace one of them now and the other pretty soon. What pump would you guys reccomend to replace since it is discontinued? Secondly, should I switch to a variable speed pump as I hear this may save on electric costs?
    Jan 2013
    Houston, TX
    1,079
    Re: What pump to replace Jandy MHPM 1.5 with
    Welcome to TFP!
    Is there anything wrong with the wet end?
    If not I would replace the motor with a 2 speed to save on electric. If you could add your pool info to your profile it will help to make recommendations.
    ... ROI on a VS is tough to realize. 2 speed was less than 8 months for me.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
