Thread: Help with Hot Tub chemicals
    Jun 2014
    Thompson, ND
    33
    Post Help with Hot Tub chemicals
    I just ordered my Taylor kit last week and used it tonight. I cleaned and refilled my 350 gallon hot tub, added sanitizing granules (4 tsp) and tested it 10 hours later.
    These are the results
    FC: 11
    TA: 140
    PH: 8
    Since the FC level is so high, does that effect the TA and PH, causing them to be high? What's the best way to get these numbers down? I have some PH - on hand.
    Any help is appreciated! I am getting so frustrated with trying to manage these chemicals
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,203
    Re: Help with Hot Tub chemicals
    Chlorine above 15 may mess up pH readings using the Taylor kit, so your numbers are probably good.
    Read through How do I use Chlorine in my Spa as it explains how to balance the TA/pH.
    Support the site
    May 2013
    Bay City, Michigan
    283
    I actually believe above 10 is where the PH readings start becoming inaccurate. Here's one of many
    Quote Originally Posted by UnderWaterVanya View Post
    Actually if FC is 10+, pH will measure high even when it really is not. Let the FC drop below 10 before checking pH any further.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Jun 2014
    Thompson, ND
    33
    Thanks. I'll test it again after having cover open and hopefully the FC will be down some.
    May 2014
    Franklin, NC
    9,203
    Quote Originally Posted by scott.MI View Post
    While I have seen many folks quote the 10 limit (including ChemGeek who I trust with his information), this is posted on the Pool School Definitions and Abbreviations Page (bold/red mine) under "pH Potential of Hydrogen"
    A measure of how acidic or basic (alkaline) a solution is. A pH of 7 is considered neutral, anything above 7 is basic and anything below is acidic. Pools are usually kept at a pH from 7.2 to 7.8. pH in pools is tested with the indicator phenol red. High sanitizer levels above about 5 ppm can interfere with this test and lead you to believe that your pH is very high when it is actually not! The better test kits will allow for this by adding a chlorine neutralizer to the indicator and calibrating their color comparator blocks to compensate for the added chlorine neutralizer so you can get accurate pH readings when your sanitizer levels are at 10-15 ppm.
    Maybe this page needs to be changed from 10 - 15 to just 10? If so I may need to adjust my testing methods as I need to keep my FC above 10 due to my high CYA.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Technically if you measure the pH quickly then the absolute FC limit is not that relevant since it is the active chlorine level that oxidizes the pH reagent to give it a false color. So when CYA is in the water, the pH will probably measure correctly at first and then drift up to the false purple color. We don't confuse things in the Pool School with this kind of info because "it depends". It's just simpler to give the rule as stated. 10 ppm FC is not a hard and fast number. It really depends on the CYA level so depends if you are at normal levels or shock levels, for example.
