Thread: White chalky film
    White chalky film
    I have a white chalky line on my travertine behind my waterfall and along waterline and vertically on each ceramic tile seam. How do I remove it and prevent it from coming back
    Below are latest test results from Leslie's....currently using their chemicals but want to switch to BBB.
    18000 gal. Includes spa
    Pebble tec
    FAC. 4
    Tac. 4
    Ca. Hardness 200
    Cya. 100
    Alk. 90
    Ph. 7.2
    Tds. 1000
    Phos. 1000
    Casey's Avatar
    SW PA
    10,453
    Re: White chalky film
    Welcome to TFP. If you want to take control of your pool and get away from the Pool Store, you're going to need a good, reliable test kit which you can look at here Test Kit Comparison. We recommend you go with the TF100 as your will be getting more reagents with the kit than with the K2006.
    Your CYA is very high. We will *ALL* recommend you do a drain/refill/retest before moving on.
    Also, it is recommended that you become familiar with the ABC's of Pool Water Chemistry.
    30,431
    Can you post a pic? That would be very helpful.
