Thread: Jandy stealth 2.5 pump won't turn on
    Mar 2014
    SLidell, LA
    3
    Today I went outside and noticed that lid to the waterway check valve had cracked and sprung a leak. Went to the pool store bought a replacement and put it I place -easy fix. Now my pump won't turn on. When you turn the system on you hear an audible click and then nothing. My husband is checking the voltage now. Pool system is less than 3 years old. What to do?
    Jan 2013
    Houston, TX
    1,079
    Re: Jandy stealth 2.5 pump won't turn on
    any humming or anything other than the click?
    I'm thinking start capacitor, it is under the bump on the motor part of the pump.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
