Thread: pool
    Jun 2014
    buffalo, ny
    1
    pool
    i have 3 valve to my pool . trying to get the water to circulate but i dont remember valve position
    water not circulating
    i turned the pump off
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: pool
    The flap inside the valve should correspond with the handle position. So the top one is open the next two are closed.
    Is that on the pipe leading to the pump, or the one after the filter (and heater if you have one)?
    I'd spend a little time figuring out which valve goes where by experimenting and then write on the pipe with a magic marker so you know which is which.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: pool
    +1, what he said about the valves and the handle position. Does the pump prime OK ??
    They look like the intakes from the pool before the pump. The pipes join together, go down and backwards to the pumps intake.
    Not sure what the pipe going straight into the ground is but I would guess it's the return from the filter since the pumps discharge also goes straight up.
    Then the is the 90deg with the flex tubing that goes into the ground ??
    Is the cover on your pump that cloudy or is the water in the pump dirty ?? If the cover looks that bad or aged you might be due for a new seal under it I had a problem with getting my pumped primed for a while and finally replaced the gasket under the cover. I inspected it and didn't see any nicks or damage but maybe it was just worn out. Was also noticing more bubbles in the pump when it was working. Works so much better now. They are only about $5 on Ebay shipped.
    Solar Blanket, Well Water, Borax Added. 76
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: pool
    Did you get it going ??
