Thread: silly pump question
    Oct 2007
    Central Texas
    silly pump question
    What happens when a primed and running pump stops receiving water? Say by shutting off a valve or an obstruction in the suction line.
    I am particularily interested in the Whisperflo and Intellipro (4x160) models. Are either of them smart enough to recognize the problem and shut down before they burn up?
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Mar 2007
    Coastalish 'down easter'
    Re: silly pump question
    It's not a silly question, but most pumps just keep trying to go - if they run 'starved' long enough either the pump will burn out or the connections and seals will melt.
    There are controls you can add to the system which will sense the loss of pressure and kill the power to the unit
    Luv& Luk
