Thread: Paint steel walls during install?
    Aug 2011
    Middle TN
    83
    So I'm probably nuts but my background is aviation and I'm used to seeing metal Zinc Chromated. Plus having uncoated metal where it could contact water (in the case of leaks) seems like a bad idea. I didn't want polymer walls because I was concerned about the long term durabilty of plastic (maybe completely unfounded). We're stalled on the pool right now and I'm VERY tempted to buy some cans of cold galvanizing spray paint and coat the walls. Bad idea? Good idea? Talk me off the ledge?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    30,431
    Re: Paint steel walls during install?
    Sounds like you are putting together a kit. Does the manufacturer suggest painting? I don't know that I have heard of that as an option.
    Aug 2011
    Middle TN
    83
    I haven't seen anything from the manufacturer that suggests painting but I was just thinking a painted surface resists corrosion better. I don't know, maybe I'm nuts. Maybe it would void the warranty or have some other disastrous consequences. I just tend to over-do things and it seems like this would be an easy thing to do that would fall in the "ounce of prevention is worth a pound of cure" but maybe not. That's why I wanted feedback.
    Aug 2011
    Watson, Louisiana
    57
    Blue skies I am thinking the same as you. My kit is on its way and was wanting to add some more protection. I was even thinking truck bed liner.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    489
    check out "por 15"
    doesn't go well on new surfaces without primer though
    use it a lot in car hobby
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
