Thread: Overrun with fleas! How to get rid of?
    May 2014
    Houston, TX
    155
    I've known that my yard has a flea problem, and I treated / sprayed the yard with permethrin with one of those spray bottle thingies where you attach a water hose to it. I did that last week.
    It helped, except now the fleas are having a party in the pool. I guess they're trying to avoid the treated areas, so the pool was their only option. Now, how do I get rid of fleas in the pool? There are thousands, even MILLIONS of them in there! I'm not kidding.
    I'm assuming it's a bad idea to spray permethrin in the pool?
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Re: Overrun with fleas! How to get rid of?
    My first thought would be to raise the FC level in the pool, but I don't know how much overlap there is between "level required to kill bugs" and "level that is safe for swimming". I have noticed that (knock on wood) insects don't seem to live long in my tub these days now that I'm treating exclusively with chlorine.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Jan 2013
    The Great State of Texas
    243
    When I was in ag class I learned that fleas float because they trap air bubbles in the little hairs on their bodies. You can't drown a flea. UNLESS you break the surface tension of the water. I was taught that shampoo in water would break the surface tension and cause fleas to drown. I don't know what gets put in pools that has an effect on surface tension, but figuring that out should make them drown.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    My pool surface was covered with the flying ants last evening. I just turned the pump on to run overnight so they would all be in the skimmers in the morning.
    Won't the pump move the fleas to their demise in a skimmer?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2014
    Houston, TX
    155
    I don't think chlorine kills the fleas, they've been in the pool for some time, just not in the numbers I saw this morning.
    Running pump now, looks a lot better now. Hope the filter picks them up.
    If I see them again in large numbers when the pump is not running, I'll post back here.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    You might want to do this when you're skimming fleas: http://www.troublefreepool.com/threa...on-Illustrated
