Results 1 to 10 of 10
Thread: Patio Pool Help!!
    May 2014
    Atlanta, GA
    7
    Unhappy Patio Pool Help!!
    Hello All,
    I am sure this has been asked, but I have searched here and the internet, read a ton of stuff, and my thoughts are all running together. I have purchased a Pro Series 14x42 AGP. The only area I have for install is on my back private patio. Obviously, for draining purposes, the pad is not level. Based on my measurements, it appears to be around 3 inches out of level. (low side). The patio measures 16x20 with smaller extension areas that wrap around under the upper deck. What is the best/safest way to level? I promise, I have read and read, used google and anything else I could think of, with no direct answer. If I keep reading and researching without finally asking, the summer will be complete before I get to assemble my pool.
    Any help and direction would be greatly appreciated.
    Thank you,
    Larry
    14' x 42" Pro Series with skimmer adapter,
    Intex 1000gph, freestanding pump w/ "A" filter
    Intex SWG.
    Aug 2013
    south east Arizona
    197
    Re: Patio Pool Help!!
    How did you figure out the patio is 3 inches out of level? that seems like a pretty large slope for a 16 (or 20) foot run of patio. If it is really that much it is too much for a pool for sure. You could get by with an inch or so but I don't think I would do 3 inches.
    There are concrete products you could use to bring the slab more level but doubt if it would be worth it.
    I would double check your level on that slab.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    May 2014
    Atlanta, GA
    7
    Pv2,,
    Thank you for the response. The measurement was taken from a smaller pool I had assembled the past three years. It was a 12x36 metal frame. (Intex with White poles/frame). I measured the water line from the high side to the top of pool, and measured the low side to the top of the pool. It was between 2.5 to 3 inch difference. I never had any issues with the previous pool for all of the years it was installed. I decided to go a bit larger/deeper this year and upgrade to the ultra frame as well. (old pool frame joints were showing a lot of rust).
    Doing the upgrade, I wanted to make sure it was done correctly this time. The pool is used mostly by me, but at times my wife will join. No rough housing, no kids. Just us sunbathing.
    Should I measure differently? I figured measuring the high and low sides of the water level would give me the best calculations.
    Again, any suggestions and help would be greatly appreciated.
    Thank you,,
    Larry
    Intex SWG.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Pv2 View Post
    3" over a 20 foot run would be less than 1/4" per foot. That does not seem like a steep slope for normal water run off of a patio.
    Support the site
    Aug 2013
    south east Arizona
    197
    1/4 inch per foot would have that patio over 5 inches off level. the husband (who is a masonry contractor) says for normal water drainage a 20 foot run might be a 1.5 inch drop.
    For the OP, I might risk a 3 inch slope if I was desperate for my pool AND the water had a safe exit if there was a catastrophic failure, but I sure as heck wouldn't advise anybody else to do it.
    I am not sure what you could do to bring it up. maybe graduated pavers for the low side and rigid foam under that got shaved down to nothing on the upside?
    Building UP to level is a lot harder (RISKIER) than bringing things DOWN to a stable level.
    May 2014
    Atlanta, GA
    7
    Pv2,
    I thought about doing as you stated. I have set up the top frame in order to see where the legs/pavers would be set. Maybe use a build up of foam board for the base, trim down until flush with upside. Afterwards, use play sand to flush each "step down" of foam board, then a heavy duty tarp over everything?
    Intex SWG.
    Aug 2013
    south east Arizona
    197
    Quote Originally Posted by lsmith9523 View Post
    Pv2,
    I would be concerned about sand just washing out, maybe some heavy duty fabric or carpet would work to make it more smooth. if you try the foam make sure it is rigid enough it won't just compress to nothing - I think there have been some recent discussions about this in regards to placing legs on the foam and the PSI calculations for different types...
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    If you use sand, you best have some kind of frame to keep it where you put it... and you'll need to wash it in/compact it really well before pool set up. A good heavy rain will compact it better than anything but if you don't get lucky and catch a rain you can compact it by hand but you will need to keep it wet or it will just poof out the sides of your tamper.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    May 2014
    Atlanta, GA
    7
    Thanks to everyone who provided direction, advice, and idea's. I am still going to think on this a few days and decide which direction I should take. If anyone reads this and has any ideas or suggestions, please respond. I am open to any help....
    Thank you again,
    Larry
    Intex SWG.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Patio Pool Help!!
    Like someone originally mentioned, there are self leveling cements you could use. That's what I would do.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
