Thread: Test Kit check, now what?
    Jun 2014
    Monterey Tn
    38
    I just received my new test kit, it is a Taylor K-2006 FAS/DPD
    just checked chemical levels, wanting now to go to TFPC here are the results I got with the FAS/DPD kit
    PH - 7.4
    CH - 110 - I think, wasn't to sure on this one
    TA - 90
    CYA - 30
    FC - .4
    CC - .2
    On the Ch test wasn't really sure I was doing that one right. Yep don't think the FC & CC are correct, never did get the water to turn pink in the tester.
    19300 gal (27x54), AG, 22"Millenium Ultimate Granular Filtration w/2HP 2SP Pump,
    July 2013, Polaris 65 Vac, Confer AG Curve Step System, Taylor K-2006 Test Kit, Nordic Sport Hot Tub 300 gal, 78.5"R X35"D
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Test Kit check, now what?
    How exciting!!
    The CH test should be straightforward. When it turns sky blue - almost the shade of the background on this page - and doesn't change anymore when you add another drop, you're done. You can watch videos of each test here: http://www.youtube.com/user/TF100TestKit
    How does your water look? If it's clear, raise FC up to 5 with bleach or some of your leftover Cal-hypo and go swimming!
    Jun 2014
    Monterey Tn
    38
    the water looks awesome. Just as clear as can be
