Results 1 to 16 of 16
Thread: First TEst with TF-100
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Well I thought I had the pool boy thing under control, looks like I need some help...
    Salt - 3900
    FC - 3.5
    CC - 0
    TC - 3.5
    CH - 1250
    TA - 100
    CYA - 50
    PH - 7.5
    Also noticing some small algae spots in a few places, not many but scattered.
    All help appreciated...thank you!
    2007 install, 27,000 gallon, IG, plaster, Pentair CCP320 cartridge filter, 2HP pump
    Circupool RJ45 SWG, Polaris 3900
    38,285
    Re: First TEst with TF-100
    The only thing really appearing to be off.is the high CH, which is only lowered by replacing water.
    Your CYA could be higher for the SWG, but with algae showing up, you need to SLAM before raising it.
    Really the CH that high is going to be a problem leading to calcium scaling.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Thank you, can I SLAM before lowering CH?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Welcome!
    Are you sure about that CH result? I'd expect you'd have patches of scale causing road rash when you brush against the walls. Did you run the test with 10 ml of water or 25 ml of water? It's easy to get confused with some tests being done at 10 and others at 25. I've made that mistake myself more times than I'd care to count.
    Did you mix until your arm turned to overcooked spaghetti? That Ch test really needs a lot of mixing. A lot. I use a speedstir, and even with that, it takes me at least 5 minutes to run the CH test to the end with CH around 800.
    Did you use Cal-hypo to chlorinate? That's a powdered chlorine sold in buckets. It could be the source.
    At any rate... if that reading is correct, I see a partial drain in your future. So be sure of that reading.
    Algae is also a concern. If you only have a little bit, a good brushing and performing a SLAM should take care of things in a day or two.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    I will re-test again to make sure of the CH reading. Was my first time using it, so it is definitely possible I added the wrong amount of water, and my mixing could have been weak. I have only used a few pucks on occasion if chlorine is low. Will repost reading. I have constantly been brushing the algae when found, but the dots seem to creep back slowly. Thank you.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Second test using 10ml of water for sure, and a good mixing. I counted 44 drops to turn water blue. So now I have a reading of 1100. Of course kinda hard keeping count when the drop count is that high, and kids asking questions constantly...
    Richard320's Avatar
    Jan 2010
    19,000
    Quote Originally Posted by Davidp View Post
    That means it's probably lower. You were only gone 15 minutes. You didn't swirl long enough. When I switched from manual swirling to the speedstir, my Ch reading dropped about 200!
    Nonetheless, a partial drain is in your future. Try testing your tap water. That will help you figure out how much to replace. Draining half won't get you to 550 unless the tap water is zero. You probably ought to plan on doing it in stages, so the pool is never closed and the kids can't get in. I use pool water on the lawn. It's your call whether you want to replace some water first to lower CYA to make the SLAM level lower, or SLAM at 50 and then slowly lower CH over several months.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Ok, thank you!
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Ok I'm ready to start the SLAM, readings are:
    FC - 1
    PH - 7.6
    CYA -40-50 (I'm not sure I quite have the hang of this test yet)
    Salt - 3900
    I don't think I have enough bleach on hand though.. And let me ask a dumb question, while SLAMing do you run the SWG along with the pump?
    Thank you
    38,285
    You can, but we usually suggest just shutting it off. Lower the pH before you start.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    I am headed into 2 1/2 days of SLAMming and today when doing the chlorine test, the pink used to turn to a cloudy clear, but it turned to a crystal clear. What does that mean? I have been maintaining 24-26 FC.
    Thank you
    Richard320's Avatar
    Jan 2010
    19,000
    Thank you
    It sounds like progress.
    38,285
    Not sure, never seen it go cloudy before. The FAS-DPD is always clear for me.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Not sure, water looks great. Chlorine level keeps dropping though. Current readings:
    FC - 17.5
    CC - 0
    Salt - 3900-4000
    CYA - 40
    TA - 100
    PH - 8.2
    Going to add some acid and stabilizer to try and get those two balanced.
    38,285
    You can not test the pH when the FC > 10ppm it will read artificially high.
    You also should not add CYA until after you complete the SLAM.
    Davidp's Avatar
    Apr 2014
    Corpus Christi, TX
    9
    Ok, thank you.
