Thread: Finally Clear Water - 1st full test results
    May 2014
    NYC
    47
    FC 11.5
    CC less than .5
    TC ~ 12
    CYA 25
    TA 30
    CH 75
    PH 7.0 (I think this is wrong since I am still at shock level)
    How do they look?
    Should I raise Alkalinity to 100? I was surprised to see this so low. Will baking soda do the trick?
    I will let the sun beat down on the FC and re-take the Ph test to see where it should really be at.
    Did I miss any test?
    I think I am close to being in!
    12' x 18' Oval Above Ground Pool (buried 2')
    Manufacturer states ~5,000 gallons
    Pentair CC75 Cartridge Filter System 1-HP Opti-Flo Pump
    Bleach Chlorination Method
    Aquabot Junior Vacuum
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Finally Clear Water - 1st full test results
    Welcome Cylon!
    I would raise the Cya, and the pH. I wouldn't worry about TA just now, that pool is very flexible in terms of hardness and TA levels.
    Use Borax or Soda Ash to raise it once the FC comes into range. It won't take long at that Cya, so let it come down first. When it does, check the pH, and use the Pool Math above to see what you need to raise it. Then, go ahead and boost up the Cya a little.
    Shoot for 45-50 at most.
    Essential Links:
    Mar 2014
    Las Vegas
    288
    Bump up your CYA. Retest your pH after your FC gets below 10.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
