Results 1 to 20 of 20
Thread: Free Chlorine,Level too high?
    May 2014
    Midland, MI
    101
    Question Free Chlorine,Level too high?
    Okay,tested pH and free chlorine level. pH level was 7.6 and my Free Chlorine was 9.5
    Is my FC too high?
    What is an acceptable level for FC?
    AGP
    16' x 32' x 54" Chesapeake
    Hayward S230T 23" Sand Filter System 1.5-HP 2-Speed Matrix Pump
    Raypak 206,000 btu ng Heater
    38,290
    Re: Free Chlorine,Level too high?
    Depends on your CYA level
    If anything more than 20ppm for the CYA, it is perfectly safe.
    See the chart in Pool School.
    May 2014
    Midland, MI
    101
    As of now, there doesn't seem to be a CYA reading. I have added dichlor the past 2 nights. My test for CYA this morning was barely cloudy.
    AGP
    Donldson's Avatar
    NW Ohio
    2,895
    If you added dichlor then you have CYA, it might just take a few days to a couple weeks to show on the tests. You can treat it as if it's 20, so it is a little high (unless you are SLAMing) but it will drop. Anything below 10 you are fine to swim and you want to keep it above 2 FC.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Dose it up to 30 and ACT like it's already present.
    May 2014
    Midland, MI
    101
    Thank you for the help. I have added the dichlor the past two nights. I will keep adding that and keep my eye on the chlorine level. I won't be adding borax tonight in order to drop my pH level down to 7.4
    AGP
    38,290
    Post up exactly how much Dichlor you have used. In your pool, the CYA will add up quickly. Use PoolMath to keep track how much CYA you have added.
    May 2014
    Midland, MI
    101
    Counting the past two nights,it would be a total of 2 1/2 cups of dichlor.
    AGP
    May 2014
    Midland, MI
    101
    Question Having a heck of a time with chemical levels
    Merged by moderator. Please keep your questions together so your full story is in one thread. Thanks, jblizzle
    Well, my chlorine has been up very high over the last several days.
    While my pool was filling I only added bleach until my test kit K-2006 and Kem trichlor arrived.
    Then I switched to just using the trichlor in the evenings, using 1 cup of the granules.
    My chlorine levels have been up to 15 mm, with very little CYA (less than 30).
    Today I checked my levels again,
    FC = 11.5
    pH = 7.2
    CYA = less than 30
    Any ideas or help would be great. I skipped adding the tricholr last night in hopes of getting my FC lower, but how can I raise my CYA without adding FC to my Intex 18' x 48" AG pool?
    We have a solar cover that we have been using, yesterday I pulled it most of the way off during the day so that the sunlight can reduce my chlorine.
    AGP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Having a heck of a time with chemical levels
    Slow down on the trichlor additions. Poolmath says each 8 oz adds 8 FC. Your other thread mentions dichlor -- what exactly are you adding?
    Just add enough powder to bring up the FC to 5 or 6 target. Don't worry; the trichlor will rise fast enough that way. You won;t lose much FC if the pool stays covered, so you actually don't need a whole lot of CYA anyway.
    The alternative would have been to buy CYA separately.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    You can get a container of just CYA and add enough to a sock to raise the CYA level to 30 ppm. Hang the sock of CYA in front of the return and squeeze it several times a day to help it disperse. Walmart usually sells containers of HtH brand CYA. It may say stabilizer or conditioner on the package. Just make sure the main ingredient is cyuranic acid and it does not contain copper or minerals.
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Midland, MI
    101
    Sorry, it is Kem-tex dichlor. I was at 15 FC the other day, yet my CYA is still very low.
    AGP
    38,290
    If you tell us exactly how much dichlor you have used, the with PoolMath you can calculate how much CYA it has added.
    This is exactly the reason we are not recommending the use of dichlor for people new to pools and the chemistry any more. You have to try to keep track of 3 different effects at once and clearly you have added too much dichlor too fast if your FC is that high.
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by mommark View Post
    Just keep dosing the FC with it according to poolmath (you can select dichlor as a source) until you've added whatever amount of dichlor it takes to get CYA up. So what if it takes a month? If the pool is covered, you don't need a lot of sun protection. It will get there. If you're at 15, you won't need to add any today and maybe not any tomorrow. When it dips, add FC.
    May 2014
    Midland, MI
    101
    Where would I purchase CYA? And is there a particular brand for the sock method?
    AGP
    Apr 2010
    East Texas
    9,602
    Walmart HTH.
    May 2014
    Midland, MI
    101
    After coming home from our camping trip, I checked the levels. I added 1cup of dichlor Thursday afternoon,just prior to leaving.
    FC was 18.0 ppm
    PH was 7.0
    CYA was less than 40
    Last night I added 1cup of borax to bring up the pH.
    We want to swim,but with a FC that high I'm afraid to let my children in the pool.
    We have had a solar cover on the pool continuously,so I removed it this morning. I am contemplating buying sodium thiosulfate. Will this help?
    AGP
    Richard320's Avatar
    Jan 2010
    19,004
    FC was 18.0 ppm
    PH was 7.0
    The FC will drop below shock level within a couple hours in sunlight. By the time you go to the pool store to spend money and get back and add thiosulfite and wait, it will be safe anyway.
    May 2014
    Midland, MI
    101
    Thank you, another question.
    When the pool solar cover is on,do the rays from the sun still lower the FC level? Our solar cover is 12 mil and is a light blue?
    AGP
  20. Back To Top    #20
    Smykowski's Avatar
    Sep 2011
    3,065
    Yes, but at a very, very reduced rate. This is one of the reasons I have the cover on the pool most of the time.
