Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: First test Taylor 100 kit
    r4m's Avatar
    Louisville/ Ohio
    40
    This is my first test with the Taylor 100 kit recommended by people here at the forum.
    Results are:
    FC=5.5
    CC=.5
    TC=6
    PH=7.8
    CH=500ppm
    TA=180
    CYA=30
    I am using chlorine tabs in skimmer.
    Poolife MPT Extra Multifunctional Tablets, (prevents algae, prevents staining &scaling formation and clarifies water)
    active ingredients: Trichloro-s-Triazinetrione 93.5%, Copper Sulfate pentahydrate 1.5%, other ingredients 5%
    thanks
    Bill
    edit: It is a round above ground 27 ft, 19,400 gal
    27 ft round, 19,400, cartridge filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: First test Taylor 100 kit
    I'd suggest other tablets if you're dead set on using tabs. Cooper = green hair and staining. I'd also suggest in a floater, not a skimmer. Trichlor is acidic and not good going directly into your pump. My best suggestion is to read more Pool School and stop using tablets at all. Your CYA is at a nice level now. Keep using tablets and it will get too high to manage your pool economically.
    Also, pH results?
    Isolated Spa - 345 Gallons
    r4m's Avatar
    Louisville/ Ohio
    40
    Thanks for the reply. I am committed to using tablets this summer. I bought enough to last the summer. PH is 7.8 (I edited the above results.)
    Isn't my CH high? If so what should I do?
    thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome! I see problems in your future..
    Yes, CH is high. It's manageable, but since you'll end up having to do a partial drain anyway to lower the accumulated CYA from using pucks, it will go down then.
    Those pucks add copper. A little isn't all that noticeable. But it does build up over time and can cause blotchy stains on the surfaces as well as green hair. When that happens, you get this: http://www.troublefreepool.com/threa...n-crunchy-hair
    Crunch some numbers... 2 ppm/day FC loss is the low end of normal. Every week you will add at least 14 FC with pucks AND about 10 CYA. By Fourth of July you will be at 70 CYA. Minimum FC for that is 5, and you might be okay. By the end of July, you'll be at 110. Minimum FC for that is 8. To get the FC up that high will mean shoving a few more pucks in the feeder, which will accelerate the rate of CYA rise, and you will be caught in a vicious spiral. You will need to replace 75% of your water to get CYA down to a reasonable-enough level so that you can afford the bleach you will need to SLAM the pool.
    Or do a weekly drain of 10-20% to keep CYA down, and then you'll get to rebalance all the new water every week.
    I've said my piece. You wrote, "I am committed to using tablets this summer. I bought enough to last the summer." Since your mind is made up, I just thought I'd get you prepared for what you will need to do to keep things balanced.
    r4m's Avatar
    Louisville/ Ohio
    40
    What would be the alternative to the tablets that would be a good route to go? It may be better than what I've committed to already. I could try to return a bucket of the tablets. Or it may be worth my $$$ to bite the bullet and go a different route.
    Richard320's Avatar
    Jan 2010
    18,967
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Quote Originally Posted by r4m View Post
    I'm in the same boat as you, OK - maybe a little worse. I have the bucket of pucks and I have fought for several months to get my CYA from 200+ to the reasonable (that is a joke) level of 100.
    Can you say WalMart? Great Valu bleach. I add about 1/3 of a gallon a day, testing chlorine & pH every day or two. The pucks are being saved for vacations when I HAVE to use floaters and I have no idea what I will do with the powered shock I have.
    Support the site
    30,400
    Both of you will be OK. The granular and puck stuff lasts FOREVER and as you learn to manage your pools, you will be able to use them to help. Just put a lid on them for now but you will not lose ANY of your investment.
    r4m's Avatar
    Louisville/ Ohio
    40
    So then if I read right, to balance my pool I need to:
    PH....add 1 qt. muriatic acid
    CH....add 229 oz calcium chloride
    CYA..add 26 oz of stabilizer
    FC=5.5
    CC=.5
    TC=6
    PH=7.8
    CH=500ppm
    TA=180
    CYA=30
    19,400 round above ground pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Your CH is already on the high side, so you don't need to raise it any more,
    You are correct about the 26 oz of CYA to raise your CYA to 40 ppm, but you probably want to hold off on the muriatic acid for now, as one of the secondary effects of CYA is to lower pH, in this case by about .2 which should put you on the high side of the normal range.
    Ike
    r4m's Avatar
    Louisville/ Ohio
    40
    Thanks Ike!
    May 2014
    Franklin, NC
    9,176
    Thanks! I already figure I will be using them for vacations when there won't be someone to add bleach. That is unless I bite the bullet and pick up a Stenner or liquidator.
    Quote Originally Posted by Isaac-1 View Post
    Ike
    Great info Ike!
    This is why I like this site. Most pool stores would just sell you the stuff and tell you to toss it in without regard for how one may react with another.
    Support the site
    r4m's Avatar
    Louisville/ Ohio
    40
    stabilizer
    Is Walmart stabilizer different from other stabilizers? Are there different qualities?
    thanks
    Re: stabilizer
    Cyanuric acid is sold under several different names: stabilizer, conditioner, etc. Sometimes those names are also used for other products. As long as you are getting 95+% cyanuric acid it doesn't really matter what brand it is.
    r4m's Avatar
    Louisville/ Ohio
    40
    Re: stabilizer
    thanks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: stabilizer
    Just be ware of other wal-mart HTH powdered pool products as many contain copper which can cause green hair and staining
    r4m's Avatar
    Louisville/ Ohio
    40
    Re: stabilizer
    Thanks Isaac.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: stabilizer
    I'm not sure when it changed, but I could have sworn the hth stuff used to be 99%. But in any event, it is 96% now, and rightly so is a little cheaper than Pool Store stuff. Plenty good enough for me.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: stabilizer
    <<<<<.Walmart cya fan. Smaller granules and dissolves more rapidly than 2 others I've tried. I like the cap/measuring cup too.
  20. Back To Top    #20
    r4m's Avatar
    Louisville/ Ohio
    40
    Re: stabilizer
    Thanks for the replies!
