Thread: Aquapure 1400 %'s Magically Changing.
    Does anyone know why the percentages on my Aquapure 1400 would change to 0%? It was set at 80% pool and 10% spa and everything was working great. The family and I left on vacation for a 5 days and when I came back I tested the water and showed 0 chlorine. When I checked the chlorine output both the pool and spa were at 0%. Any idea why this would happen? Thanks in advance. I am still new to the salt water scene and am trying to figure everything out as I go along.
    Re: Aquapure 1400 %'s Magically Changing.
    It sounds like the unit is broken.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Were you able to set it back to your normal output? Did you lose power while you were away? Is your panel accessable to anyone other than you? How old is the unit?
    Welcome to the forum!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jun 2011
    Long Beach, CA
    2,786
    Did you make any % change to the output?
    Sometimes when I change the % output the unit will take it but the next day it will have changed to something else. I always make sure to look at the % the next day after making a change.
    Quote Originally Posted by ComputerGuyInNOLA View Post
    Yes, I was able to set the output back to its normal output.
    It doesn't appear that i lost power while I was away but I can't be 100% sure. Even if I did lose power wouldn't it retain the settings?
    The only person who would have access to change the settings would be the person I had feeding my dog. It's controled by the onetouch panel and wont take commands at the outside panel.
    The unit is only a couple of months old.
    I will check it this evening when I get home to see if it retained the %'s that I put in last night.
    Quote Originally Posted by ping View Post
    I didn't make any changes to the %'s before I left.
