Thread: Will bleach settle over time in a container with some pool water added?
    Jun 2013
    East TN
    309
    If I mix 2 jugs of 8.25% bleach and 1 jug of pool water in a container and let it sit will the bleach settle to the bottom over the course of a week with no circulation? I believe this mixture is 5.5% bleach. The bleach and water will be mixed prior to sitting. I think I saw a description like this in the chlorinator manual. The chlorinator gets aggitated I guess but Im talking about still water. This is a project Im working on.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Casey's Avatar
    SW PA
    10,453
    Re: Will bleach settle over time in a container with some pool water added?
    Well, bleach is heavier than water. That is why it is recommended to pour in front of a return, pencil thick so it gets distributed and does not sink to the bottom of the pool. I'm sure someone else will chime in soon to give their $.02.
    Mar 2007
    San Rafael, CA USA
    12,082
    If the bleach is mixed with the water, then it will not settle. Though bleach is denser than water, that is only relevant when pouring into still water. Once mixed, it stays mixed, especially in a volume of water as small as a bucket. Diffusion alone will overcome any gravitational differential in that small a volume.
    Jun 2013
    East TN
    309
    Good deal. As usual thanks for the replies.
    In some cases, impurities in the pool water can cause the bleach to lose strength more quickly than normal even though it now has a lower concentration.
