Page 1 of 4 1234 LastLast
Results 1 to 20 of 73
Thread: Above ground pool install
    Jun 2012
    Long Island, NY
    102
    Well after two years with the intex 15 round ordered a 18 round 54 high sharkline matrix. Arrived via trucking on a skid today.
    Decided to use the foam cove along with the 1.5 foam for tthe bottom. In the early stages now of leveling the ground. Its much more difficult then I expected. Anyways this is just the start.
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    Casey's Avatar
    SW PA
    10,444
    Re: Above ground pool install
    Congrats on the new pool! Good luck on leveling! It is by far the worst part of installing the pool and the most important! Keep the pics coming!
    Jun 2012
    Long Island, NY
    102
    Thanks. I think the hardest part was finding the lowest spot because the high spot seemed to be right in the middle of where I wanted the pool.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2012
    Long Island, NY
    102
    Still leveling.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    It's worth it, I'm about to start leveling myself! You leaving grass all around the pool?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I'm currently levelling too... Its a necessary evil and I hate it, but when you get it right its so satisfying.... Congrats on a nice clean level so far....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2012
    Long Island, NY
    102
    Quote Originally Posted by Slammed01 View Post
    Sent from my SPH-L710 using Tapatalk
    The circle is a foot bigger then the pool so will probably put rock and a boarder. Not 100% sure just yet.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2012
    Long Island, NY
    102
    Not level yet but sod is gone.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2014
    206
    Quote Originally Posted by burmjohn View Post
    Sent from my Nexus 7 using Tapatalk
    So 19' or a 20' circle? Bye bye sod!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,444
    Yes... You have to over dig to accompany the post and give yourself room to work.
    Jun 2012
    Long Island, NY
    102
    Foot bigger on all sides so its a 20 foot circle.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2012
    Long Island, NY
    102
    The weekend is here. Leveling. Few more hours to go
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2014
    206
    Awesome, I like the updates and progress pics!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,444
    Do you think you'll get it up soon?
    Jun 2012
    Long Island, NY
    102
    Well everything is level. I was unpacking the stuff for the matrix pool from poolsupplyworld and 4 of the bottom cuffs had clips snapped off. Will have to see how long it will take to get them replaced.
    I did run out to home depot and got the pavers and foam. Going to work on getting the pavers in tomorrow.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    I had the same issue with my sharkline due to poor packaging from the manufacturer, PSW was fantastic and handled the RMA very quickly
    Good luck with the rest of your build
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Casey's Avatar
    SW PA
    10,444
    When I got my pool, I had the boxes open that day looking through them. It was mid March and snowing outside! Hubby was shaking his head but I had to see what I had and didn't have and inspect the parts. But you know, you are not the first one to report broken cuffs with the Matrix. I think I read of 3 other members with the same broken tabs. They do replace them but it's ridiculous. I have the Venture and all my parts were perfect! Hope you get them soon and don't have to wait long! They usually send them out without question if I remember correctly.
    Jun 2012
    Long Island, NY
    102
    Hopefully PSW will come through asap.
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
    Jun 2012
    Long Island, NY
    102
    Quote Originally Posted by tick221 View Post
    Anything else an issue besides the cuffs?
    Thanks - John
    Filter Type: Sand
    Pump: Intex 2650
  20. Back To Top    #20
    Nope once I got the replacement cuffs it went up nice and easy, we were in it today
