Thread: Lowering FC
    Oct 2013
    Mount Joy, Pennsylvania
    19
    Lowering FC
    This is the first summer with our pool. Last couple days water testing have been very consistent....haven't even had to add acid to lower the pH.
    pH 7.5
    FC 11
    CC 0
    TA 70
    CH 300
    CYA 80
    My question is about how to lower the FC. I know it's safe to swim and all but it really doesn't need to be that high I don't think. We haven't been in the pool yet because the water is too cold (no heater, yet), 72 deg. So I'm trying to figure out my pump run time with the SWG %. We have pump set for 12 hours on, 12 hours off. I had SWG at 40% three days ago, and each day I would lower the percentage and tonight after testing and seeing the FC was STILL at 11 (for the last 3 days), it's now set to 0% and I will test again tomorrow evening. Would it make sense to just shut off the SWG until the FC level drops? Using the TF-100 test kit.
    Thanks!
    13K gal, 16x32 IG vinyl, Hayward SuperPump 3/4 HP, Hayward Perflex DE filter, AquaRite SWCG T-15. Hayward SharkVac. AquaCal T-115 heat pump. Built Oct 2013. TF100 test kit. Borated.
    38,295
    Re: Lowering FC
    That is way more pump run time than you need. I would shorten that and see where the FC settles.
    My pool is bigger with the same SWG, I run 8 hours at 50%, so you likely need less than that.
    Oct 2013
    19
    Re: Lowering FC
    Thanks....didn't know it was okay to run pump that short of time on account of keeping the dirt filtered out and all, we have a lot of trees around. Do you do the 8 hours during the day or at night, or doesn't it matter? Thought I read somewhere that daytime is better.
    38,295
    Re: Lowering FC
    Likely 4 hours is enough, see the article in the How To section of Pool School. I only run that long and during the day for solar heating purposes.
