Thread: SLAMing questions
    May 2014
    Burlington, NC
    45
    SLAMing questions
    I started SLAMing Wednesday evening. Just curious if these numbers look normal and am I doing this right? It continues to clear more and more and I think the DE has been a big help. Any idea how many more days it may be?
    My FC #s after SLAMing to a 20FC shock level each time have been:
    WEDNESDAY
    6:15 = 17.0 ppm
    10:00 = 15.5 ppm
    THURSDAY
    8 am = 13.0 ppm
    Noon = 17.5 ppm
    4:00 pm = 14.5 ppm , add 1 cup DE
    9:00 pm = 18.0 ppm, add 1 cup DE
    FRIDAY
    8 am = 18.0 ppm, add 1 cup DE
    12 noon = 16.0 ppm, add 1 cup DE
    4:00 pm = 14.5 ppm, add 1 cup DE
    9:30 pm = 12.5 ppm, add 1 cup DE
    Thanks for any insight on this process!
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Casey's Avatar
    SW PA
    10,427
    Re: SLAMing questions
    We can tell you if you are right on if you add your CYA levels. You are more than likely right on if you have seen marked improvement. No one knows how long it can take from start to finish. Some clear in a week and others can drag on for weeks on end. What I would suggest is to not let up on the SLAM and continue to beat it into submission by bringing up the SLAM levels as you have been doing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Are you backwashing each time? Otherwise, stop adding all that DE! You'll clog your filter. It just forms a thin layer on top of the sand that is finer than the sand. Picture putting a window screen over a barbecue grate. Same thing, just on a microscopic scale. If you're not backwashing it out, it's like layering screen after screen on top.
    Just watch the pressure and backwash when it rises 25% over the clean pressure after the last backwash, then add another cup of DE.
    The number progression looks good.
    May 2014
    Burlington, NC
    45
    Okay, Casey, my CYA level was at 50 when I started so I don't guess that has changed. Did not check it today. Richard320, I have definitely backwashed before each SLAM and before each cup of DE. My "clean" filter pressure is at 10% and I backwash at around 13-15%. Is there a point I should stop adding DE before it is clear?
    Sta-Rite pump, 1HP?
    Richard320's Avatar
    Jan 2010
    18,983
    Quote Originally Posted by mamalou23 View Post
    Nope. Run it all the time if you want! You probably have a big enough bag to keep you going for years!
    As long as you're backwashing, ignore my last post.
    May 2014
    Burlington, NC
    45
    Good. I will keep doing what I've been doing then and thanks so much for the affirmation.
    Sta-Rite pump, 1HP?
