Thread: Need help. Too much Phosfree. Now filters are clogged
    Jun 2014
    Edmond, OK
    2
    I'm a relatively new pool owner and was unaware of the dangers of adding too much Phosfree at once. Well, now I do, but it is a bit too late. My jets are barely pushing out anything. My question is: will this type of clogging work itself out as the phosfree mixes or is it time to clean the filters?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Need help. Too much Phosfree. Now filters are clogged
    Clean up time.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome
    Yup. Time to put on the grubbies.
    We have directions for cleaning sand filters and DE filters as sticky threads at the top of http://www.troublefreepool.com/forum...umping-Station
    Isaac-1's Avatar
    SW Louisiana
    6,711
    We generally feel Phos Free is never needed in a properly balanced pool, and just something the pool stores use to extract your money
    Jun 2014
    Edmond, OK
    2
    Thank you all for the feedback. Sadly, the more research I've done, the general public seems to echo that sentiment about Phosfree not being nearly as important as the stores would lead you to believe. Anyway, I guess that's part of the learning process. Thank you all very much.
