Thread: Aquapure 1400 with Error Codes 172, 190 and 191
    Jun 2014
    Harpers Ferry, WV
    2
    I have a Aquapure 1400 that hasn't worked yet for me this season. I have error codes 172, 190 and 191. Has anyone seen those three error codes together and what would be the easiest fix for it? Any help or advice would be greatly appreciated.
    Re: Aquapure 1400 with Error Codes 172, 190 and 191
    Welcome to TFP!
    Are you sure that isn't actually a 171? Code 190 is supposed to always show up along with 171.
    Jun 2014
    Harpers Ferry, WV
    2
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
    I'm sure it's 172. That is what confuses me so much. Everything I've looked up previously online shows 190 and 191 with error code 171.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Welcome!
    How old is your system? You could have two issues feeding errors. Have you cleaned your sensor and checked all the plugs/wires/connections?
    If you can...post a pic of your system (the cell, control center etc.).
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    May 2014
    Mesa, Arizona
    180
    Check out this link, it lists all the error codes and the problems associated with them:
    http://www.poolsupplyworld.com/blog/...g-error-codes/
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
