Thread: Did I just ruin my pool
    Hello.
    I have a splash super pool, 17x29, and had it filled yesterday. I wasn't here, unfortunately, and when I got home I noticed that one of the white legs popped out of the aluminum rod as it was filling up. So from the weight if the full pool the white leg ripped and popped through the white border around the top of the pool.
    It gets worse....
    After seeing this and dying a little inside, I noticed that two other legs also popped out on the same side and are not in the aluminum rail. These two have not punctured the white border on the pool, but all 3 of these occurrences are on the same side of the pool.
    I know as soon as people get in the pool and start playing around the other two legs will rip though the pool.
    Is there anyway to fix this? Without draining the entire thin? Will it last the summer?
    Thanks
    Re: Did I just ruin my pool
    I think your only choice is a complete drain and then see if you can get things reset so they will stay in place.
