Results 1 to 8 of 8
Thread: SWG and rain
    Jun 2014
    Baton Rouge, LA
    6
    SWG and rain
    Here in south Louisiana we get a LOT of rain. I feel like I am constantly having to add salt because the rain dilutes the pool whenever we have a downpour. Is this normal?
    Re: SWG and rain
    Welcome to TFP!
    It is not that common to get enough rain to really make a difference. Most years we have an inch or two of overflow over the entire season, which really isn't enough to matter. This year we have already had 8" of overflow, so it is starting to be an issue.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SWG and rain
    Yes, it's normal, but only in proportion to how much rain you have as Jason said. An inch will hardly do anything, while 6 will make a dent.
    If you know your pool size, it's very easy to figure volume and you can easily nail that down to gallons per inch of water added or lost.
    Essential Links:
    Re: SWG and rain
    I would be careful not to add too much salt - once that water has evaporated, the salt level should drop to normal - unless you're draining or there was significant overflow.
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: SWG and rain
    Penny, I am in Mandeville, La so I am familiar with the issue. We just added 40 pounds of salt last week because of all the rain we had a couple of weeks ago. We dropped from 3300 to 2800 in a week. We have had to add salt twice in the last year due to heavy rain. I would wait until a couple of days after the rain has subsided and make sure the salinity reading from your SWCG has stabilized and does not change. You will need to turn off your SWCG for 24 hours after adding salt and run your pump the whole time. We have a drain near the top of our pool that automatically drains it so it does not overflow. We must have had 12-14 inches of rain in a 7 day period. It was hard for the drain to keep up. Good luck.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Re: SWG and rain
    Quote Originally Posted by ComputerGuyInNOLA View Post
    Yikes! I guess we're talking apples and oranges here. Thats A LOT of rain.
    Jun 2014
    Baton Rouge, LA
    6
    Re: SWG and rain
    Thank you, ComputerGuy. That is exactly the kind of rain I'm talking about. We've had about 8" so far this week and it's predicted to rain again tonight. We have an automatic lever as well, I guess that's what you mean by drain, so it hasn't overflowed, but it is much higher than normal. After 4 1/2" the other day the salt level dropped from 3000 to 2850. We just cleaned the SWG yesterday so I am going to wait to see if the salt level will come back up when the water level stabilizes.
    I'm concerned, however, with the chlorine level being zero. If it doesn't get rained out, my daughter is having a swimming party tomorrow. The water was looking pretty greenish last week, but after shocking with 10 gallons of bleach, the color is beautiful now although we still have 0 FC. Should we be concerned about swimming in it with no chlorine?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: SWG and rain
    Yes, there needs to be chlorine in it before anyone should be swimming.
