Thread: CL levels after fighting algae?
    Mar 2007
    Ontario
    211
    O.K So plan on losing half the FC level thoughout the day?
    Bump it to 8ppm at night if I want to maintain 4ppm?
    Before this bloom I don't think I ever bumped it higher then 3 or 4 ppm.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CL levels after fighting algae?
    You'll have to allow for the loss during the day so that the chlorine doesn't get below 4ppm before the next evening if that's where you want to keep it. I'd nudge the CYA up to 40ppm to cut down on your daily loss.
