Results 1 to 11 of 11
Thread: Economical cleaner
    Economical cleaner
    I'm looking for an economical cleaner and have been considering the following:
    Barracuda g2,
    Mx-8
    Thepoolcleaner
    Polaris 360
    I have an 18x36 inground, sand filter. No dedicated cleaner line. Which would you recommend? Want to stay under $500. Mostly concerned with sand, dead algae and some leaves and maple keys. Are there any others I should consider?
    Using Tapatalk
    Re: Economical cleaner
    No one?
    Using Tapatalk
    Jul 2009
    Olney, MD
    218
    How would you hook up the Polaris 360?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    On one of the returns...
    Using Tapatalk
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I don't know much about all of the various types of cleaners, however, I do know that the polaris 360 works with its own return line that is connected to a booster pump.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    38,271
    Without a dedicated cleaner line, you can not use a pressure side cleaner which leaves you with a suction cleaner (I would recommend the PoolCleaner) or a robot (limited selection under $500).
    Jun 2011
    Long Beach, CA
    2,781
    The PoolCleaner, very happy with mine 3.5 years and only replaced the tires.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Ive read good reviews about ThePoolCleaner, though I have never used one.
    I dont recally any negative reviews about them.
    Divin Dave,
    Actually I believe the 360 and legend II run off a standard return, no booster pump required. I'm really leaning towards a robot, but the initial expense sure is off putting.
    Using Tapatalk
    Oct 2011
    Minnesota
    164
    You could buy a Kreepy Krauly on Craigslist for ~$100. We have been happy with ours.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    38,271
    Quote Originally Posted by tbell_1 View Post
    They may not need a booster pump, but you still need a dedicated cleaner line so you can force enough water flow through it using valves. If you just try to hook it to one of your regular return jets, the path of least resistance for the water will be to the other jets and the cleaner will not get enough flow ... unless ... all your returns are plumbed separately to your equipment pad and you can close off the non-cleaner ones if needed.
