Thread: What kind of pool do I have?
    Jun 2014
    New Albin, Iowa
    1
    This is our pool (see pictures). It was here when we moved into our home. I know for certain this pool is at least 10 years old because I swam in in about 8 years ago before I moved into the home. We are trying to figure out what kind of pool this is and what kind of liner we need to order to replace the current one. I have been told that the pool is not a doughboy. I have also been told that I would need an overlap liner. Can anyone offer anymore information? We believe the pool is 21 x 41.
    Orlando, FL
    690
    Re: What kind of pool do I have?
    I don't know what kind of pool it is but I don't think that matters when it comes to buying a liner. Measure the pool if you don't know the dimensions. Then, decide what type of liner you want overlap, beaded, etc. Then figure out the mil, which is the thickness. I think most will agree 25 mil is the minimum. Hopefully, someone else will provide additional feedback.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Casey's Avatar
    SW PA
    10,424
    How tall are the walls? If they are 52"-54" you can use a J Hook liner or you can go with an overlap liner. J Hook/beaded liners come in many patterns while overlap liners are more plain Jane. Definitely get a 25 gauge liner as they are stronger, regardless of overlap or J Hook/Beaded.
