Thread: BulbWizards PoolBright 202 LED Color Changing Replacement Bulb Review :: Recommended
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    When I was looking into replacing my 300 Watt incandescent bulb with a color changing LED on, I didn't see anyone report on the PoolBright 202 from BulbWizards.
    It was significantly cheaper than other similar bulbs, so I gave it a look. Here is what I found:
    • Made in USA
    • 3 Year limited warranty
    • They have it for sale on eBay, Amazon, and their own website bulbwizards.com, for the same price ($164)
    • On eBay they have 100% positive rating with 278 reviews.
    • On Amazon they have a few negative comments, but they responded to each negative comment and appear to be genuinely interested in helping resolve issues, which carries some weight in my book
    • Comes in 12V and 120V
    I bought on eBay since that gives you significant power as an unsatisfied customer.
    Impressions:
    • It arrived well packaged and seemed to be well manufactured. It had way more weight than I expected.
    • It fits perfectly in my Amelite 8 1/2" light fixture. It really fills it up, with maybe 1/4" gap all the way around. Much larger than the incandescent bulb, but obviously designed to fit standard pool fixtures.
    • It has 7 constant color settings (Red, Yellow, Green, Aqua, Blue, Purple, and White)
    • It also has 4 "ColorMorph" settings where it cycles though the colors. These vary in time from rapidly changing "disco" mode, to 30 minutes per color.
    • Mode changes are accomplished with your standard on/off switch (no remote necessary). Cycling the power off and back on within 8 seconds (and as quickly as 100 milliseconds) advances to the next mode.
    • Apparently multiple bulbs can be easily synchronized, but I only have only light, so I couldn't test this.
    As far as the light it gives off:
    • Colors vary in brightness. This is apparently caused by a combination of the different lumens produced by different color LEDs and the fact that certain colors are actually made by turning on several colors simultaneously, so these colors have the additive brightness of each of those colors individually.
    • At it's brightest (white) it is noticeably dimmer than a 300 watt incandescent bulb. To me this is a good thing. I really didn't like the intense light given off by the incandescent bulb. I always felt like it was blindingly bright relative to the darkness outside.
    • Red is the dimmest. It is probably enough light for safety, in that you can see the steps and walls, but it definitely doesn't have that glowing illuminated pool look.
    • All the other colors look great. Deep saturated colors, and enough brightness to give the pool that glowing illuminated pool look without being too bright.
    • I have run it for several hours a few nights in a row, and never experienced the dimming issue noted in the Amazon reviews.
    Overall, I would definitely recommend this bulb. For about half the price of the ColorSplash 3G (which is probably the closest competitor to this bulb) it is absolutely worth it.
    BTW, I tried to take some video last night, but my iPhone couldn't do it justice. I will try to take some shots with my SLR and a tripod, and will post them soon.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    May 2015
    Grapevine, TX
    4
    Re: BulbWizards PoolBright 202 LED Color Changing Replacement Bulb Review :: Recommen
    Thanks Svenpup, I've been looking at replacing my lights with LED. Good review, probably the best prices I've seen for replacement bulbs. Still working well?
    25k in-ground
    PebbleFina w/ Spa
    Jandy RS-8
    Polaris w/ separate pump
    Waterfall, separate pump
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Yup. Even working after the fixture flooded. Dried out and reinstalled no problem.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I thought it would be worthwhile to post a follow up review. I haven't seen any chatter regarding this bulb, which surprises me since we TFP-ers pride ourselves on finding the bargain pool supplies.
    I am now past the three year mark and it still works perfectly; even after the fixture flooded two years ago (and flooded with salt water no less). The price is actually $35 cheaper than it was when I purchased.
    I am in no way affiliated with this company, but I feel compelled to spread the word.
    funandsun's Avatar
    Jun 2017
    Bloomington Indiana
    692
    Thanks for the follow up. I am going to be replacing our bulb in the next few weeks, still works but we want the LED and color choices they offer. Your review has helped me out.
    13k gal, IG Vinyl (2004), Infinity 2000 Recessed/Top Track Pool Cover (2004), Pentair SuperFlo VS (2017), Hayward S180T Sand Filter (2014),
    Pentair R201276214 Pro Vac (2017), Taylor K-2006+SpeedStir (2017) PoolMath
    2009 HotSpring Vanguard 400 gallon spa (2009) Overnight Chlorine Loss Test FC/CYA Chart
    Rule #1: SLAM Kills Algae, Your Filter cleans the water
