Results 1 to 12 of 12
Thread: R-0870 - Only 1 scoop?
    ebbnflow's Avatar
    May 2014
    Northern California
    3
    Long time reader. First time poster. I finally severed my pool from the death spiral of Leslies this year. I am using liquid bleach instead of those darn stabilized pucks and my pool has never looked better. I had to re-up on my chlorine test reagents and was just reading the reviews on amazon. This is what one of the reviewers said:
    " DID YOU KNOW?
    The instruction pamphlet that comes with Taylor's testing kits say to use TWO scoops of this DPD powder, but if your test water sample turns pink after adding just ONE scoop of this reagent, you don't need to add a second scoop? As long as the water turns pink after adding the first scoop of powder, the testing procedure is unaffected by not adding a second scoop. What that means to you is that you can test your water for twice as many times now before you have to buy a replacement reagent bottle.
    And that saves you money!!! "
    I have yet to prove this to myself, but I would like to know if anyone has used this method with success? My water sample always changes to pink after the first scoop, but I have always added a second scoop, because that is what the directions I have say to do.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: R-0870 - Only 1 scoop?
    Yup, I seldom use two scoops. Generally with my freestanding spa and there is no color change with one scoop (meaning no chlorine. )
    Support the site
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    The TF-100 Kit, that many of us use, includes the R870, and the instruction to use one heaping scoop. You should be just fine.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mar 2011
    Houston, Texas
    413
    FWIW, when I first started using the little scoop that came with my kit I assumed the handle (looks like a small paddle) was the scoop. It never occurred to me that the tiny little scoop end could put enough powder into the sample to matter. Heck, I didn't even notice it was a scoop until I saw a picture in a thread. So I was probably adding several times the amount of the DPD powder than I should have been adding.
    When I found out I was using the wrong end of the scoop and started using the correct end, my results did not change. So, for me, adding way, way too much of the powder did not affect the results. I think it's been said here before that you want to add enough of the powder to change the sample to pink. That's always one scoop for me.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    38,237
    You can not use too much powder, but too little can cause issues. If you are in maintenance mode (FC < 10ppm), then one scoop should be fine if you get a nice pink color. If you are SLAMing with high FC levels, that is when you likely want to use 2 scoops to ensure you have enough powder, again look for a nice pink ... too light or a flash of pink and you need more powder.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    We know, my guess is that 1 level scoop may be not enough some of the time, and the people that write the instructions at Taylor think saying one heaping scoop sounds unprofessional so they say 2 scoops instead.
    Ike
    ebbnflow's Avatar
    May 2014
    Northern California
    3
    Thanks for the replies. This forum is a blessing. My pool would not be crystal clear without the wealth of information I have read here.
    13000 Gal IG Plaster Pool and Spa - 320 Sq ft Fafco Solar Hot Water Array - Hayward SP2302VSP Main Pump - Hayward/Leslie's 48 Sq ft DE Filter - Hayward 400,000 BTU NG Heater - Some old school spa pump - Polaris 280 Sweep powered by a Pentair Pump - Liquid Chlorine using TFP Method
    38,237
    Glad to here the forum has helped you ... consider Becoming a TFP Supporter to keep the forum running ... you will note that we do not bring any money in from ads all over the place like most other forums.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I heap my one scoop like a slob and love it.
    Isolated Spa - 345 Gallons
    Ellington, CT
    262
    With the size of the scoop I'm thinking that one heaping scoop is equivalent to two level scoops.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    I've measured several times. One heaping scoop averages about the same as two level scoops, but has more variation in quantity from "heap" to "heap"
    Casey's Avatar
    SW PA
    10,421
    Quote Originally Posted by JVTrain View Post
    I'm not the only one!!!
