Results 1 to 9 of 9
Thread: Returns "spitting air"
    Feb 2014
    Camdenton, MO
    59
    I wondered if this is normal. The returns tend to occasionally "burp" and spit air bubbles...almost like there is air in the system. Wondered if this is normal, or if I may have an air leak somewhere I need to address...
    In-Ground, Vinyl Liner, Sand Triton II (Pentair?), 1HP Whisperflo?, approx 25K gallons. There is a separate spa (non-functional). Heater is new last year, 250,000 BTU Hayward propane. Pool built in around 1996, liner replaced in last 5 years.
    May 2014
    NYC
    47
    Re: Returns "spitting air"
    Quote Originally Posted by mjb62676 View Post
    This happened to me and I was losing pressure on my pump. Air was being introduced into my system through a drain plug that was not on quite right.
    I found a video on youtube of someone demonstrating how lighting 3 sticks on incense to create a cloud of smoke and bringing these sticks close to every point where air can sneak in on the suction side. When I did this, I saw the cloud of smoke being pulled to where my problem was. Quick and easy fix using this method.
    Hope this helps
    12' x 18' Oval Above Ground Pool (buried 2')
    Manufacturer states ~5,000 gallons
    Pentair CC75 Cartridge Filter System 1-HP Opti-Flo Pump
    Bleach Chlorination Method
    Aquabot Junior Vacuum
    Feb 2014
    Camdenton, MO
    59
    Thanks...we had trouble priming the pump at start up because we think one of the intake lines has a small air leak so I suspect this is the culprit.
    I'm going to work on the assumption that we shouldn't be seeing these burps and bubbles.... I appreciate your help.
    Air in the returns is normal only if you have a solar system or the pump was primed recently. Otherwise it usually means there is a suction side air leak.
    Feb 2014
    Camdenton, MO
    59
    I have had to remove the filter basket from the pump several times in the last 2 weeks to clean it....I wonder if this may have something to do with it. Hopefully have some time to mess with it this weekend and figure it out.
    SLAM is nearly complete. We could see the drain this morning.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Very possibly. Rule one with mechanical work: the last thing you worked on is the first thing that leaks. So check that pump basket cover O-ring. Even a blade of grass can cause problems. Make sure it's lubricated good, too.
    A sticking weir (flapper) in the skimmer or low water level allowing a vortex in the skimmer can also produce what you describe.
    Feb 2014
    Camdenton, MO
    59
    Thanks Richard. I'll check it out. Don't have any "flappers" on the skimmer inlets.
    Feb 2014
    Camdenton, MO
    59
    The skimmer baskets appeared to be "Stuck up" allowing water to vortex, and this was causing a lot of air in the system.
    Richard320's Avatar
    Jan 2010
    18,984
    Find a rock too big to fall in the skimmer pipe and drop it in the basket. Problem solved.
