Thread: Re: Stains on replastered pool
    Jun 2014
    Plano, Texas
    1
    Moved from http://www.troublefreepool.com/threa...plastered-pool Please start your own thread when you have a question. Butterfly
    Quote Originally Posted by JasonLion View Post
    Try placing a vitamin c tablet on one of the stained areas and see if the stain clears up in that spot.
    I have a similar problem. About 6 weeks ago my landlord replastered the pool. No after care was done that I know of. I could see white powder at the bottom of the pool. The main drain had been sealed off years ago due to rupture. No brushing, no vacuuming. I did find 2 empty bottles of muriatic acid in the recycle bin so I assume that is what they did. I have since purchased a brush, a vacuum and a skimmer and have cleaned as best I could and the yellow stains are still there. I tried the vitamin c trick and it appears to do nothing. Yesterday I tested the water and the FAC and TAC were both at a 2, the pH was 7.4, Calcium Hardness was low at 150 ppm, CYA was at 35, the TA was a 40 and I added 10lbs of Alkalinity Up from Leslie's, it called for 12 1/2 lbs, the TDS was 900, and the phosphate level was at 200. From what I have read these stains were caused by poor curing. What can I do to get rid of them? I am also seeing what appears to be black spots.
    Thank you.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    I'm sorry no one responded yet. You should probably try and keep your FC from dropping below 3 and with your low CYA you'll probably lose a lot of chlorine from sunlight. If you have stains from poor plaster workmanship I don't know how to fix that. Perhaps someone with more knowledge in that area can help.
