Thread: How much calcium in cal hypo?
    I know I've seen this, but I cannot find it. How much calcium does a given weight of cal hypo add to the pool? I am considering getting some 73% cal hypo to add calcium to the pool while chlorinating to get my calcium readings to readable levels. I can do the math on the % in each pound of stuff I put in the pool, but I cannot find the basic answer to this question. Thanks
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    30,432
    bleachcalc....under "more calcs"
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Chris,
    Welcome to TFP. Let me see if I can point you in the right direction. Download BLEACH CALC 262 onto your desktop. You should be able to get the information you are looking for inside this program. If you get the chance, thank Michael (MWSMITH2). Again, welcome to the site.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Riles_J's Avatar
    Nashville, TN
    218
    73% Cal Hypo adds 0.7ppm CH for every 1.0ppm of FC.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Thanks for the quick responses. The bleach calc tells how much calcium chloride one would need, but I was considering using calcium hypochlorite for both chlorination and to raise my calcium a little. If the Bleach Calc has this calculation, I am not smart enough to find it. I know it was posted one time in Pool Forum, but I can't seem to find, how much calcium does calcium hypochlorite have per pound. This would determine whether I buy a 25 lb bucket or, say, a 50 lb bucket of the stuff.
    Chris
    Thanks Riles
