Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Algae or Metal
    Jul 2013
    Blair, Nebraska
    26
    Algae or Metal
    We have well water with iron in it. I'm having a tough time knowing whether I'm still fighting algae or if I have metal staining going on. I've been SLAMing, keeping FC > 14.
    Current results:
    FC 18
    CC 2.0
    CYA 35
    TA 150
    PH 7.2 when I started
    I vac the bottom once a day and always get some brown, though I'm vacuuming blind and can't really see what's going on there. I sort of wonder if there's a hole in the liner in one certain spot that always seems to generate dirt.
    Am I still fighting algae or could this be metal staining?
    18K gal 28ft round AGP, Hayward Power-Flo LX 1.5HP pump, 22" diameter round Sand filter 150lbs
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Algae or Metal
    With CC at 2, I'd say it's still algae.
    Maybe you should recheck the CYA. Maybe the FC isn't high enough. It's a tough test. There's no shame in pouring the sample back into the mixing bottle and taking a dozen readings if necessary until you start to see the same number come up enough to notice.
    PS: that grit you find is probably iron precipitating out. Vacuum it up and flush it out and be rid of it! If the water is still greenish when the FC holds overnight and the CC is low and the water is otherwise crystal clear, then it's metals and a sequestrant with clear it up in very short order.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    Is this algae? This pic is from yesterday after vacuuming. There was much less today.
    Richard320's Avatar
    Jan 2010
    19,067
    Re: Algae or Metal
    No, that's just windblown debris. The garden hose on jet stream and a scrub brush will clean that out.
    You can minimize that by stretching a knee-high nylon over the skimmer basket to stop it from getting through to the pump.
    Pictures of skimmer nylon
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    Thanks for the link - that's helpful.
    Yeah, we've had some 'windblown debris' out here lately! Perhaps you've heard about the storms that rolled through Blair earlier this week. Amazing weather! Another storm went through last night (not severe) and I'm again vacuuming green leaves out.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    Well, things aren't working out so well. Last year I used Jack's Pink Stuff and had clear water. This year I tried Robelle Mineral Out and had no success. After dumping two bottles, I called Robelle and they suggested two more. That didn't help.
    I ordered four bottles of Pink Stuff and put two in. No change, so per the label I added two more. I still have green water.
    FC 4.0
    CC 0.5
    TA 50
    CYA 50
    PH 6.8
    Here's a pic. Any suggestions?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: Algae or Metal
    You need to SLAM
    *Shock
    *Level
    *And
    *Maintain
    You keep it there (shock level for your CYA)until:
    Water is clear
    No CC's
    You can pass OCLT
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Sep 2011
    Lumber City, Ga
    9
    Re: Algae or Metal
    Your ph is too low. Suggest you get it up to 7.2 or so ASAP
    24x48 Atlantic AGP
    18" Hayward Sand Filter
    1 HP Hayward Powerflo LX
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    You need to SLAM
    Okay, I started SLAM last night.
    Is that related to the color of the water or for swimmer comfort? Could you clarify (no pun intended ) why it's important. Robelle suggested lowing the Ph and Chlorine both before adding product so that's what I have been doing.
    Thanks.
    Re: Algae or Metal
    PH below 7.0 can damage the pool. If it is really 6.8 that isn't a big deal, but the test will report any PH below 6.8 as 6.8 so your actual PH could be much lower.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    I've been slamming. The water is less bright green, slightly more grey. Not much change in color but there definitely is a change.
    I am concerned that the filter might not be working properly. I put two nylon knee-highs over the skimmer basket and that caught some fine debris. Since the nylon seemed to help, I added a piece of an old white T-shirt under the nylon in the skimmer basket. Within a couple hours, the shirt material was completely clogged with green slime and the pump was starving for water. I pulled the shirt out and just have the nylon in now.
    Should I try something different to try to improve filtering, or am I on the right track? The pool has not been clear at all this year. I feel like I'm spinning my wheels and going nowhere.
    PH is up to 7.2 now.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae or Metal
    Are you backwashing when the pressure rises 25% above clean filter pressure?
    Have you deep cleaned the filter: http://www.troublefreepool.com/threa...-a-Sand-Filter
    Confirm the filter is working properly and then you could try adding DE: http://www.troublefreepool.com/conte...-a-sand-filter
    What size/pounds is the filter? Add info to sig
    ooh, wait. Your pool is still green Don't add DE yet.
    What FC level are you maintaining?
    Can you confirm the CYA level?
    The best thing to do is keep SLAMing. You are on the right road.
    You're done SLAMing when:
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    I have been keeping FC above 18. It's been getting a gallon of bleach every morning and evening.
    Current results:
    FC 18 (right before I added another gallon)
    CC 0 (finally!)
    CYA 50
    The filter is 22" diameter and takes 150lbs of sand. I put new sand in this spring. I'm backwashing about every day.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    Eventually I will be done with SLAM (hopefully!). Remember I already put in four of Robelle Mineral-Out and four Jack's Pink Stuff. I've had to add a couple inches of water twice to replace what's being lost to backwashing so there is un-sequestered water or whatever you want to call it in there.
    Should I order more sequestrant now so I'm ready when the time comes?
    I ordered refill chems for my test kit and will be able to post full test results tonight.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    Success.
    The water is clear. We can see the bottom! It still has enough dirt on it that even vacuuming like I was, blind, I missed a lot. Now that the bottom is visible, we'll just have to vac to waste a couple of times to get it cleaned up.
    And... the water is barely tinted green any more! I guess the previous sequestrant wasn't wasted after all!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae or Metal
    Have you passed the three criteria to determine that you have completed the SLAM process? See red lines in my sig.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    No, I haven't finished the SLAM yet. I was just pleased that we are making progress. There is still a bunch of dirt and debris in the bottom of the pool... we vac to waste until the water level is too low, add water and bleach, then let it settle overnight and do it again. Today might be the last day of that. Once we're done adding water daily, I'll try an OCLT and see where we stand.
    I think all this started when we didn't cover the pool for the winter. There are no trees around but still a lot of dirt and debris made its way into the pool. I learned to turn the pump off overnight to let it all settle down, otherwise the water was just too stirred up to know what was going on.
    Either way, it's getting there! Thanks for the help so far.
    Richard320's Avatar
    Jan 2010
    19,067
    Re: Algae or Metal
    If it's just dirt and silt, why not vacuum to filter and then do a backwash? Less water used.
    Jul 2013
    Blair, Nebraska
    26
    Re: Algae or Metal
    The filter seems to plug rather quickly and then starts blowing dirt/silt back into the pool, starting the problem all over again.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,067
    Re: Algae or Metal
    Quote Originally Posted by twosocks90 View Post
    Sounds like the sand is clumped up into clods and the dirt makes its way through the cracks between. A deep cleaning ought to fix that.
