Results 1 to 8 of 8
Thread: Algae coming back after shock. Stressed!
    Mar 2013
    Baltimore, MD
    30
    Hello all,
    Just uncovered my pool this week and it was pretty well green. After some bad advice and a few lessons learned I came to you guys to get me straight.
    I thought I won the war on algae but noticed it's creeping back.
    I've been testing my water daily and yesterdays numbers were
    FC 1-2
    TA 80
    CYA 18
    PH 7.5
    CH 130
    I should note that my shock FC was 12 and that was using liquid bleach on Wed.
    Today I added 2 more gallons of bleach brining my FC number up to 6.
    Talk to me, what do I need to do to rid myself of this for good? Higher FC levels over a longer period of time?
    What I'm seeing.
    1988 installed, 45,500 Gal, IG, Gunite w/spa
    60 sqft DE Filter, Pentair WhisperFlo 2 HP WF-28 pump, "Shasta" infloor cleaner.
    Jun 2012
    Rochester, NY
    247
    Re: Algae coming back after shock. Stressed!
    What are you using to test? Do you have a recommended test kit?
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    Mar 2013
    Baltimore, MD
    30
    The big TF 100 kit.
    Jun 2012
    Rochester, NY
    247
    Quote Originally Posted by BauerR View Post
    The big TF 100 kit.
    Excellent.
    Is your CYA really 18?
    What is your CC?
    I'd go ahead and SLAM. I'd also consider raising your CYA up to 30-40 to help hold the chlorine. At least after you pass the OCLT.
    Rick
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Sounds like you need to SLAM (Shock Level And Maintain)...
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Donldson's Avatar
    NW Ohio
    2,881
    If your CYA is really 18 (the test doesn't go that low...) then your chlorine is burning off in the sunlight. Raising it to 30-40 will help you lose less during the day. After that a full SLAM will remove the algae and keeping FC within the proper range for your new CYA level will keep it from coming back.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2011
    Houston, Texas
    413
    Is the picture of an area of poor circulation?
    Even though yours is green, I get a small amount of black algae at the water line along one side of my pool (along the tanning ledge) that gets poor circulation. Frequent brushing helps.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Did you "shock" the pool, or did you SLAM? SLAM = Shock Level And Maintain.
    How many days did you have to keep the FC up to shock level to eradicate everything and pass the overnight loss test?
