Results 1 to 11 of 11
Thread: LED strip lighting question?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    My pool has a strip light along the edge. It doesn't seem super bright but its OK. One area in a corner it has come away from the wall about 1/2" and pushing on it (thought I could use some clear caulk) will not seat it back in. I guess it shrunk at some point.
    My question is do they make new strips that will fit and be brighter? Secondly if I want the entire thing flush in its groove I am guessing I have to remove it completely? Kind of why I wondered if I should replace it with a brighter strip?
    Lastly I am not sure how these things work, there is a black light box at the end of the pool, in order to turn the light on it starts up a motor. Do these things use a ton of power or something?
    Thank you!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: LED strip lighting question?
    LED's by nature don't use much power. usually the black box is a transformer, as they often work off of 12V DC.
    New strips may/may not be brighter.
    on the strip seating issue, pictures are worth 1000 words.
    Make sure you get outdoor rated waterproof LED strip if you decided to replace it.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Sorry I should of taken a picture of the trouble area! I will update this tonight.
    So the transformer has a fan or something in the housing that I am hearing rev up?
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    plausible, I believe some of the higher output transformers have cooling fans.
    Are you sure those are LEDs? What you describe sounds like fiber lights. The light is in the box with a fan, and is conducted to the edge of the pool via fiber.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Hey Jason, I didn't even think about that. I was curious why LEDs would need a transformer with cooling fans being such low voltage. Fiber makes a lot more sense. Wonder if the fiber lights can be upgraded to something brighter? I wish the pool had better lighting at night its so dim you can't see the bottom, and it has this tiny little light under the skimmer that does almost nothing.
    Jun 2010
    74
    I don't know about the strip lights, but you might be able to upgrade the underwater light with a higher wattage one, or with an LED one that is brighter.
    Also look into something like these - LED lights that screw into your pool returns and use the water flow to power themselves. I've seen them available in both plain white and crazy disco psycho colors. These might be a low-cost/low-effort solution for you, depending on how many returns you have and how bright the ones you get are.
    * Responsible for the operation of 21 semi-private pools and spas at 11 locations, varying from 1,900L to 20,000L spas and from 13,000L to 200,000L pools.
    Apr 2013
    Sacramento, CA
    2,769
    I'm betting this is a fiber optic strip light. A picture would help, including the box with the fan.
    There are pictures of several models here.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    It may just be that you're system needs cleaning. If a spider built a web between the lamp and the fiber bundle or some dirt or rust has dropped onto the bulb, the light output could dramatically drop. Any place there is a fan, lots of dust and dirt will build up over time.
    There's also the possibility that someone replaced the lamp with a lower wattage version.
    I suggest opening up the box, checking the bulb and wiping down the fiber cable end with a wetted rag or q-tip. Sort of like driving with a clean windshield, light transmission will be greatly improved.
    Edit: And if there's a reflector behind the bulb that's just a rusty mess, that may be an easily replaceable part. Otherwise make sure it gets polished up too.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Thanks gtemkin! I wasn't sure how they worked, I will open it up and take a look!
