Thread: Going with the 12x24x52 intex. Which pump filter to upgrade too?
    Jul 2011
    Albuquerque, NM
    38
    Ok weve decided "bigger is better" so we are going with the intex 12x24x52 pool. Ordering it today. It comes with a sand pump that I think you all agree is not helpful with the amount of gallons we will need to clean. Can anyone recommend a better filter/pump and if I will need different fittings for the new filter/pump than the ones intex provides? I need to go back and re read pool school since it has been years since we've done this but I'd like to order what I will need today. I'll also need to get a new test set from here.
    Thank you for any help.
    Jenn
    Jenn, From New Mexico
    8600 gal Intex 12x24x52 ultra rectangular pool, current filter: Sand Filter Pump with 1,600 gallon (6,056 L) per hour flow rate
    Jul 2011
    Albuquerque, NM
    38
    Re: Going with the 12x24x52 intex. Which pump filter to upgrade too?
    Ok so here is the pump the pool comes with: Krystal Clear™ Sand Filter Pump with 1,600 gallon (6,056 L) per hour flow rate
    What should I be looking for in a better filter/pump?
    Thanks for any help.
    Jun 2014
    Centennial, CO
    8
    I have the same pool being delivered on Tuesday and am wondering the same thing. I have the saltwater system that I purchased a couple of years ago and didn't use because I couldn't get enough water flow that I want to try, as well as either a gas heater or solar panels(still undecided if I have enough sun).
    Intex 12x24x52, Hayward S210T sand filter pump, Solar panels on roof. Lots of work for a 65 year old!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    An above ground 1hp pump and any style of filter that can handle the flow rate from the pump, the bigger the better.
    http://www.troublefreepool.com/conte...ter-comparison
    Of course you will have to install regular pool fittings, and either hard plumb or buy pool rated pressure hoses to fit. Search the forums for ideas on how to do this. There are many of us (Intex owners) that have taken that step. Much better overall filtration and circulation.
    This chart is about 1/2 the minimum we recommend for filter sizing. If you can afford to triple the size shown in the chart for your water volume, do it. You will not regret the decision.
