Thread: Muriatic Acid Question
    I recently purchased Muriatic Acid Next from Lowes. It has a green rather than a blue label and it has less fumes and lower odor. Is it as effective as the regular Muriatic Acid in lowering the Ph?
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: Meria tic Acid Question
    You likely purchased a lower concentration formula. The low fume version is typically 10 baume (15.725%) versus the 20 baume (31.45%). You can use it but it will take more volume to do the required PH reduction. If you use the poolmath sheet here, change to the concentration on the label.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Muriatic Acid Question
    Jt is correct.
    It will work but take more of it to do the same job. I would suggest finding 31.45% strength.
    Essential Links:
    Apr 2014
    Eastvale, CA
    4
    Use the blue label from Lowes. I've tried both and found only the blue label really works.
    Thanks for the help! I will go back to the blue label.
    East TN
    Raypak Gas Heater
    May 2012
    Cincinnati, OH
    189
    I would encourage you to do some price comparison on this as well if you are paying the $7.29 per gallon as advertised on their website, I suspect you can do much better from another source. I've been buying 31.45% at Menards for $3.99@
