Thread: Pump looses prime over night... is this normal?
    May 2014
    Clinton, Mississippi
    24
    Pump looses prime over night... is this normal? It primes right up when I turn it back on. It takes about 20-30 seconds to prime. I thought I read or watched on youtube at some point that the pump supposed to stay primed...
    ____________________________________________________________ ___________
    15,000 gallon in ground pool with liner, Purex Triton Tagelus sand filter, Pentair Superflo 1HP.... Clinton, MS.
    38,539
    Re: Pump looses prime over night... is this normal?
    The only way to lose prime is if there is a leak in the system.
    Jun 2014
    Phoenix, AZ
    7
    I've chased a leak for a while...anything short of getting all new stuff I can't find it!! Mine takes about 10 seconds to get up to speed. I'm good with that I suppose.
    12,000 gal pebble tec, 2 hp Hayward 1 speed pump, S310T2 Hayward sand filter (5 square feet filtration)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You're not getting air in the basket when it's running correct?
    If not then it's on the pressure side, (after the pump). If it's only taking 10 seconds to get up to speed I wouldn't worry about it.
