Results 1 to 7 of 7
Thread: That TFPC Clean Pool Smell
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Until owning my own pool this year, I had only swam in other people's pools (probably poorly maintained) and commercial pools. They all had a typically pungent aroma of chlorine, those dreaded combined chlorines. Now that I have a well balanced pool of my own, I've taken to... taking in it's smell. When I'm in the pool, I get a slight hint of that chlorine/bleach smell but almost nothing. When patrolling my pool deck with the skimmer net for rogue maple seeds and doomed insects I smell almost nothing. Almost. The only way I can describe it is a faint hint of something similar to antifreeze. I can't help but remember the jugs of RV antifreeze that were in the skimmer buckets when I opened the pool for the first time. The lines were properly winterized and obviously some of that antifreeze went in my pool from the lines when I opened. Could I possibly be still smelling it? It's an extremely faint aroma but that's all that comes to mind when I smell it.
    What do your pools smell like? Anyone else who has to completely winterize in a colder climate have a similar take?
    Isolated Spa - 345 Gallons
    Casey's Avatar
    SW PA
    10,448
    Re: That TFPC Clean Pool Smell
    I don't use antifreeze because I have an above ground pool but I just told my husband the other day that our pool smells so good. I wouldn't say it's a chlorine smell but it's a nice and clean smell. Then he said, I'm so glad you take such good care of the pool!
    brian4110's Avatar
    May 2013
    Pennsylvania
    131
    Quote Originally Posted by JVTrain View Post
    I'm glad you posted this because I experienced the same thing and I used anti-freeze this past winter. For several weeks after opening, I could get just a faint whiff of that sweet anti-freeze smell. I didn't smell it last year. (And yes, I used pool/RV anti-freeze!) I did vacuum most of the anti-freeze to waste upon opening, but I think a gallon or 2 made it into the pool. I was told that shouldn't be a concern. FWIW, the pool guy I spoke to about closing said he would have used 12 gallons of anti-freeze to close a pool my size. I used 6 and thought that was overly generous. Glad I didn't take his advice!
    The smell has faded quite a bit but is still barely there. I'm sure I am the only one who can smell it...I might be part bloodhound.
    18' x 41' IG w/vinyl liner. 30000 Gallons. 78" x 78" poolside spa
    1.5 hp Hayward pump - sand filter & not quite working Tiger Shark QC robot
    Automation: Compool CP3800 Control Panel Pentair to Compool EasyTouch Upgrade
    TF-100 kit
    Built in 2002. "Inherited" w/House in 2012. Located in Pittsburgh
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Yup, you can hardly notice any smell of chlorine on your when you come out. And when in the pool, I can't smell anything. Love it!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    We always joke that our pool is like swimming in bottled water. No funny smells, crystal clear, soft on the skin.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Casey View Post
    At least you know it's appreciated. That's worth it!
    Quote Originally Posted by brian4110 View Post
    Me too! I bark occasionally as well but that's after a few whiskeys. Good to hear someone else has at least had the same experience. I imagine maybe in a few weeks I won't smell anything at all.
    Quote Originally Posted by elwood58 View Post
    I like that analogy. Maybe it should be on every preppers doomsday plan to have a TFP balanced pool for a monstrous emergency supply of drinking water. Sometimes I think our pool water might be more pleasant to drink than city water!
    Mar 2007
    San Rafael, CA USA
    12,082
    See the thread Pool water safe to drink in emergencies?. It would be better to use water from your hot water heater, if available.
